Directadmin Custombuild Problem
latheesan
Directadmin Customapache Problem
I noticed that my host gave me PHP 4, so I decided to use "Custombuild" option to upgrade php and apache at same time. So, I followed this guide and did this :
./build clean
rm -f configure.*
./build all
When it finished, I got the following output :
* All parts have been installed *
Type: /sbin/service httpd restart
[root@server customapache]#
So, i followed the instruction and typed the following command :
As soon as I did this, i got the following error :
Stopping httpd: [FAILED]
Starting httpd: Syntax error on line 1 of /etc/httpd/conf/extra/httpd-phpmodules.conf:
Cannot load /usr/lib/apache/libphp5.so into server: /usr/lib/apache/libphp5.so: cannot open shared object file: No such file or directory
[FAILED]
Can you help please? Where Im I going wrong?
I even tried this instruction :
./build clean
rm -f configure.*
./build update_data_ap2
./build apache_2
./build php_ap2 n
./build mod_perl_ap2
and at the end, i typed this command :
I get the following error :
Starting httpd: Syntax error on line 18 of /etc/httpd/conf/httpd.conf:
Cannot load /usr/lib/apache/libperl.so into server: /usr/lib/apache/libperl.so: undefined symbol: ap_table_merge
[root@server customapache]# /sbin/service httpd start
Starting httpd: Syntax error on line 31 of /etc/httpd/conf/httpd.conf:
Invalid command 'Order', perhaps mis-spelled or defined by a module not included in the server configuration
[FAILED]
what it means ?? I see many line have Order, deny allowed .....
I don't know what's wrong ... that's why i posted here hoping someone would reply with a possible fix.
Right now ... my web server isn't working ...
Don't use customapache if you are using custombuild configuration files. It will fix your problems:
./build all d
./build all d
LOL That's what I did and this is where my problems started. :eek:
The best way to install apache 2 and php is with custombuild:
http://files.directadmin.com/services/custombuild/1.1
[root@server2 custombuild]# /sbin/service httpd restart
Starting httpd: [Sat Jul 26 10:37:25 2008] [warn] module php5_module is already loaded, skipping
Syntax error on line 16 of /etc/httpd/conf/ips.conf:
User cannot occur within <VirtualHost> section
Btw, line 16 shows: CustomLog /var/log/httpd/homedir.log homedir
Search the forums a little more...
All is good.
echo "action=rewrite&value=ips" >> /usr/local/directadmin/data/task.queue
/usr/local/directadmin/dataskq
