Directadmin errors, HELP!!
yton
Hello DirectAdmin members,
I've installed DirectAdmin on my server for a year, but now there is some strange.
First: I every day get the following error by the message system:
Subject: Reseller admin is missing 'bandwidth' from their reseller.conf
Second: When I want to create a reseller or an user IN THE ADMIN ACCOUNT , I get the following errors:
Creating that many Domains would put you over your limit of
Creating that many Pop Accounts would put you over your limit of
Creating that many Ftp Accounts would put you over your limit of
You cannot create more Users than you are allowed domains.
You currently have 7 Users and a maxium of domains.
Can someone help me?
I thought about it yesterday, and what if you reïnstall DirectAdmin? Can you hold your users, domains, nameserversettings etc?
I'm from The Netherlands, so sorry for my bad English.
Thank you for your support.
Yton.
I can't help you with the first question, but it sounds like someone knowledgeable would be able to help you out pretty fast.
As for the second one, I imagine it must be some sort of a configuration error. But I'll be curious to hear what the cause is.
Don’t reinstall just yet – I’m sure it won’t be too hard to fix.
It seems your configs are a bit corrupted or something.
Reinstalling is a very bad idea, as you loose all your data, but creating a backup won't work, as it's your userdetails data that's corrupted.
Warning, dutch below:
Als je het probleem eens in het Nederlands wilt bespreken, pm me dan maar even... Dat gaat misschien wat makkelijker dan engels :).
Translation; If you want to talk about this problem in Dutch, please pm me... Might be a bit easier than English :).
Yes, Dutch is a bit simpler for me!
But if you (reader), have suggestions, don't hestitate to post a reply.
Translation:
Ja, is goed, ik heb je een pm gestuurd, laten we het saman oplossen, bedankt!
Thank you,
yTon.
