I have installed DirectAdmin in Amazon EC2 and it is working.
However, I have a problem about to way to retrieve license file in DA control panel.
it will retrieve via eth0:0 which is DirectAdmin IP Address license in directadmin.conf. However, it cannot be download via that interface.
when I going to install, I following this blog. it remove '--bind-address=IPADDRESS' parameter from `wget` command. that mean it go though eth0 interface (not eth0:0)
Now, I can manual update via directadmin script. (by remove --bind-address parameter) but cannot retrieve a license from DA control panel.
Anyone have any suggestion to make it work?
Below is message received when trying to update license via control panel.
This is an automated message notifying you that an error has occurred while trying to update the license file.
The generated message is as follows:
Unable to connect to 66.51.122.131<br>
Unable to connect to secure socket<br>
Unable to connect to any site for a license update<br>
Please contact JBMC-Software, including the error message. Failure to do so could result in an inactive control panel.
Please note that I have already configure Security Group to allow connection from that ip address in any ports.
