Solved "directadmin-ips.conf" secondary IPs can't serve static contents larger than 1mb
Ohm J
This thread will useful for information for anyone encounter this issued.
All IPs showing here is fake.
NGINX_REVERSE
I have problem about this.... 2 years ago (maybe since I start add addition IPs).
my server have 3 IPs ( public IP ), so main IP work fine because it running by "/etc/nginx-vhost.conf"
like /phpmyadmin, /roundcube, Statics contents doesn't work. So now, I trying debug again. somehow there have a bit weird of files between sizeof greater than 1mb and lower than 1mb,
files size lower than 1mb still work fine. so Now I decide to unused "directadmin-ips.conf" for now to workaround fixed my problem.
Example: enter site
it work fine with return code 200;
When trying to enter static files bigger than 1mb.
it return code 404;
When trying to enter static files bigger than 1mb with main ips
it return code 200; ( work fine )
So only problem with addition IPs that work with "directadmin-ips.conf"
But when I unused/remove "directadmin-ips.conf", It will running with "nginx-vhost.conf" and work fine again.
It's a weird problem.
This is weird, when you try open file via IP which didn't have virtualhost with appropriate document-root you must receive 404 for any requested file, no matter what size it/type it.
it IP Linken.
all IPs link to main IP. and problem only with webapps like phpmyadmin, roundcube ( /var/www/html/* ).
All domains work fine ( only enter site with IPs is problem ).
yes, just checked - it has include for wepapps on each additional IP vhost
