directadmin style problem after install suphp
mohammad
hi ,
i install suphp and it's works good , but i have new problem ! now my directadmin skin have problem ...
you can see in this image =>
how can i solve this problem ?
It might help to save the packages one extra time to fix the missing language in your skin. Try this:
Click on "Reseller Level" and then click on "Manage User Packages", click on the package name that you use, then click on "Save" - then log in as a user and check if the problem is solved.
Edit: Also your image does not work. If you want more help, then please edit your forum post and remove that image link. Then upload a image and add as attachment to your post. The current link seems like a spam link to me, please remove it.
reply
php -v
PHP 5.2.17 (cgi-fcgi) (built: Jun 24 2012 23:12:46)
Actually seems isnt taking language tags, try reinstall skin and be sure to have lang set to en.
how can i reinstall directadmin default skin ?
The problem is not resolved
Unfortunately I do'nt have permission to modify my posts :(
thank you for advices
It seems you've got no PHP -CLI installed (for now it's only guess), try to make sure you've
which php
output similar to
[root@server ~]# which php
/usr/local/bin/php
and then again
/usr/local/bin/php -v
If you have no /usr/local/bin/php or you still see
then you need to install PHP-CLI. Your system still needs to have PHP-CLI though you will run suPHP (PHP-CGI) with Apache.
./build php d
Then try again
to make sure you see something similar to
PHP 5.x.x (cli) (built: Jun 21 2012 18:22:53)
Thanks for answering my questions :)
./build php d
after i run these commend's , all user's site show Internal Server Error 500 , i search a lot a bout this error on this forum but i can't solve that !
after run these command , when i run php -v command , it's show that , this command not found !
but my direct admin skin problem solved , but Internal Server Error 500 is new problem :(
when i cant solve Internal Server Error 500 problem . a gain i run script to reinstall Apache 2.2 + PHP5.2 + Suphp ....
now Internal Server Error 500 is solved , but skin ...
By the way, how did you do that? Did you use custombuild script?
i use this script to install Apache 2.2 + PHP5.2 + Suphp
#!/bin/bash
#Copyright 2010 (c) syslint.com
RED='\033[01;31m'
GREEN='\033[01;32m'
RESET='\033[0m'
clear
echo -e "$GREEN*************************************************************$RESET"
echo -e "     Directadmin Apache 2.2 + PHP5.2 + Suphp + Suexec Autobuild script"
echo -e "          Copyright (c) 2008-2011  http://syslint.com/ "
echo -e "         Your  Directadmin Server Management Partner  "
echo " "
echo " "
echo "The installation will start within  10 seconds "
sleep 10
./build clean
echo -ne "Cleaning  for custome build   .."
echo -e "[ $GREEN done $RESET ]"
echo -ne "updating custome build .."
mkdir -pv custom/ap2
mkdir -pv custom/suphp
echo -ne " Creating custom folder /usr/local/directadmin/custombuild/custom "
rm -rf custom/ap2/*
rm -rf custom/suphp/*
echo -ne " Cleaning Custom Folder .. "
echo -ne " Downloading configure template ... "
wget -c http://files.syslint.com/da/conf/suphp/configure.apache.conf
mv -vf  configure.apache.conf  custom/ap2/configure.apache
wget -c http://files.syslint.com/da/conf/suphp/configure.php5.conf
mv -vf  configure.php5.conf  custom/ap2/configure.php5
cp -vf  custom/ap2/configure.php5 custom/suphp/
wget -c http://files.syslint.com/da/conf/suphp/configure.suphp.conf
mv -vf configure.suphp.conf custom/suphp/configure.suphp
chmod 755 custom/ap2/*
chmod 755 custom/suphp/*
echo -ne "Changing php5-cli to php5-cgi ..."
sed -i 's/php5_cgi=.*/php5_cgi=yes/g'   /usr/local/directadmin/custombuild/options.conf
sed -i 's/php5_cli=.*/php5_cli=no/g'  /usr/local/directadmin/custombuild/options.conf
echo -ne "Starting apache Build"
./build apache
echo -ne "Starting php build"
./build php 5
echo -ne " Creating /usr/local/lib/php.d .."
mkdir -p /usr/local/lib/php.d
echo -ne "Creating Soft links ...."
ln -sf  /usr/local/bin/php-cgi /usr/local/bin/php
ln -sf /usr/local/bin/php /usr/bin/php
echo -ne "Editing /usr/local/suphp/etc/suphp.conf ..."
sed -i 's/x-httpd-php5=.*/x-httpd-php5=\"php:\/usr\/local\/bin\/php-cgi\"/g' /usr/local/suphp/etc/suphp.conf
echo -ne "Setting php.ini path .."
sed -i 's/suPHP_ConfigPath.*/suPHP_ConfigPath\  \/usr\/local\/lib\//g' /etc/httpd/conf/extra/httpd-suphp.conf
/etc/init.d/httpd restart
echo -e "--------------------------------------------------------------------------------------------------------------"
echo -e "                               Installation Completed"
echo -e " Get Support for your Directadmin Server from $GREEN http://syslint.com/DirectAdmin-Server-Management$RESET"
OK, I see you should not use that script for installing suPHP.
Run this instead:
./build set php5_cli no
./build set php5_cgi yes
./build rewrite_confs
./build php d
./build suphp
That should fix your both issues, and install PHP-CLI and suPHP with PHP-CGI, which are supported by custombuild without any 3rd parties scripts.
hi
zEitEr
Run this instead:
./build php d
./build suphp
hi , is run this command befor , when i run these command's skin skin is ok , just i see one error , you can see image
http://up.vatandownload.com/images/eguqibxzogpz2n80ecw.jpg
but all server site's show Internal Server Error 500 :(
Check domain error logs and suphp logs for understand what's wrong, usually should be a permission error or htaccess error.
Regards
