Directadmin / system monitoring scripts?
Navigator
Hi all,
I'm looking for a script that can monitor, alert and try to mitigate minor issues on its own on my directadmin system - 10 years ago or so I used to rely on System Integrity Monitor (SIM https://www.rfxn.com/appdocs/README.sim) but this project seems to not be up to date? Are there alternatives to full-blown zabbix or other more complex things out there that I can simply install and forget it (ala 'csf')?
Thanks in advance.
I don't know the exact method but it just checks to see if its running. It does not check to see if its responding. I wrote a separate script for that.
Service Monitor will alert you and try to restart.
