Hello!
After i installl new server, i have problem with disk usage. DirectAdmin show wrong disk usage (du -sh * - show real disk usage).
For example if real quota (without statistics file, but with mails and logs) is 50 mb, directadmin show 68 mb or more .
I try to reinstall quota, i try http://help.directadmin.com/item.php?id=42 and i try use the "echo 'action=tally&value=all' >> /usr/local/directadmin/data/task.queue" but it not help.
I try to find on forum, but i can't find solution for same problem.
I have:
Linux CentOs 4.6 : core 2.6.9-78.0.8.ELsmp
DirectAdmin (last version)
My disk structure:
Filesystem Mounted on
/dev/sda1 /
/dev/sda2 /tmp
/dev/sda3 /var
none /dev/shm
Soft:
Apache 2.0
Awstats
PHP Version 5.2.6 (suphp)
Any ideas?
I have:
My disk structure:
/dev/sda1 /
/dev/sda2 /tmp
/dev/sda3 /var
none /dev/shm
Soft:
Apache 2.0
Awstats
Any ideas?
