DNS changing - problem.
foekk
Let me explain my "case".
I have 3 domains:
kuffi.net + hosting
rofcheck.net
(I have one DIRECT ADMIN for these domains)
and a separated DA for:
freepicz.net + hosting
Both hosted by the same company.
What I want to do is "connect" rofcheck.net with the hosting that right now is connected with "freepicz.net".
I've read about the DNS Menu on sites like site-helper.com and it sounds logic.. only problem is I don't see this menu in my DA?? Don't get it.
If anybody could help me out.. please.
You only get to control your own DNS records if your hosting company allows it; contact them.
Unless your hosting company gives a separate IP# for each domain you host, you won't be able to do what you want to do with DNS but will have to use some kind of rewriting or aliasing.
Your hosting company can help you.
