DNS Problem
You need to setup your nameservers properly. there have been several threads on these forums regarding that.
That will clear up some of the errors.
thank you.
but where can i find the thread ?
Can you post the link here ?
thank you very much.
DNS Report shows your nameservers as:
ns1.cck.hk. [202.65.97.187]
ns2.cck.hk. [202.65.97.194]
Are those the right IP#s for your server?
If not, then you need to change the nameserver names at the site registrar where the domain is registered.
If they are, then your nameserver isn't running.
Here's a simple test:
Logged in through a shell account (not necessarily as root), try:
dig @localhost yourweddingclub.com
and tell us what you get.
I have set the nameserver incorrect before.
The correct IP for my server is 202.65.97.180 and 202.65.97.181.
I have set the correct IP now. But it's still can't running.
And I do not understand what is your meaning....
Thank you.
jmstacey,
or i give the directadmin's username and password to you.
and you help me..... can you ?
Named isn't running and can't be started from DirectAdmin. You'll need to login via ssh (or physically) as root and investigate the reason DA can't start it.
hi jmstacey,
have you receive my usename and password ?
If so, can you login to my DirectAdmin and help me ?
I did, that's how I got the information that named isn't running. But DirectAdmin can't start it.
I'd need root ssh access to investigate why it can't further. ;)
