Domains transfer problem between 2 directadmin servers
shupi
Hello.
I come here because i got a problem when transfering some domains from a directadmin server to an other.
Let's start with config :
OLD SERVER : ns313465.ip-188-165-221.eu - 188.165.221.53
NEW SERVER : ns353084.ip-94-23-248.eu - 94.23.248.50
So to transfer a domain, here's what i've done :
1- Done a backup of site script and Database
2- I changed the DNS on my domain provider (OVH) from :
ns313465.ip-188-165-221.eu 188.165.221.53
sdns2.ovh.net 213.251.188.141
TO
ns353084.ip-94-23-248.eu 94.23.248.50
3- Deleted the associated user on OLD SERVER
4- Created a new user associated to the domain on NEW SERVER
It's about more than 48 hours i've done the transfer but i see there is a problem on DNS config, because the IP of the OLD SERVER remains in the config and I don't know why, as i removed the user (and so all the dns config of the domain ??) from the OLD SERVER.
you can see that here :
http://www.intodns.com/ahora.fr
NS records got from your nameservers listed at the parent NS are:
ns313465.ip-188-165-221.eu ['188.165.221.53'] [TTL=14400]
sdns2.ovh.net ['213.251.188.141'] [TTL=14400]
ns353084.ip-94-23-248.eu ['94.23.248.50'] [TTL=14400]
and so some errors come with :
FAIL: The following nameservers are listed at your nameservers as nameservers for your domain, but are not listed at the parent nameservers (see RFC2181 5.4.1). You need to make sure that these nameservers are working.If they are not working ok, you may have problems!
WARNING: SOA MNAME (ns313465.ip-188-165-221.eu) is not listed as a primary nameserver at your parent nameserver!
Sa you can imagine, website is not reachable from anywhere. I made 3 domains transfer with exactly the same problem.
Thank you for your help.
Best regards.
As far as i can see everything is fine now, so or it was just matter of time or you did actually fix your problem changing some wrong configuration?
Regards
