Domains will not resolve
Petertjuh360
Hello guys,
I discovered that new domains will not resolve to my nameserver.
IntoDNS says that my nameservers don't respond.
If I enable recursion for "any" the domains will resolve, but IntoDNS says it's better to have recursion off and recursion off worked before I got this problem.
Error message in log:
Jul 14 16:36:14 server1 named[20575]: client IP#48091: query (cache) 'domain/A/IN' denied
Kind Regards,
Peter
For recursion you should normally have this in your named.conf:
        allow-recursion { localnets; };
However, it's difficult to help and to look whats wrong without knowing the real nameservers which are having the problem.
Since there is a denied notice... either the domain is not present on your server, or did you deny query's?
allow-query {none;};
If you have this line, either remove it or change "none" to "any". And don't forget to restart named after it. :)
Hello Richard,
I had it set to localnets before.
It was the allow-query which I had to set to "any" to make it work again.
It must be changed or needed since an update of named.
Thanks for your help!
Kind Regards,
Peter
