DoS-Deflate Problem?
rmxs
Hello i have setup DoS-Deflate
the setting is for ddos is the default..
I have also make the fix that i have post here http://directadmin.com/forum/report.php?p=138713
I get mails
Banned the following ip addresses on Sun Sep  7 12:25:01 EEST 2008
62.38.xxx.x5 with 290 connections
That mean this ip is banned..
Ok were is baned?
##### Paths of the script and other files
PROGDIR="/usr/local/ddos"
PROG="/usr/local/ddos/ddos.sh"
IGNORE_IP_LIST="/usr/local/ddos/ignore.ip.list"
CRON="/etc/cron.d/ddos.cron"
APF="/etc/apf/apf"
IPT="/sbin/iptables"
I dont have apf installed
i try with my ip..
the system recongine the many connections and sent me email that my ip is banned..
i try to connect via ssh i try to acceess my site and everything its normal?
You have any idea?
I already use
##### APF_BAN=1 (Make sure your APF version is atleast 0.96)
##### APF_BAN=0 (Uses iptables for banning ips instead of APF)
APF_BAN=0
i try it from my system email with ip comes to me byt i can access the server like before
What i discover so far.
Maybe the ddos works ok byt my question is..
When one user request 1 page how many connections needs?
I get many mails per day that some ips is banned..
I make the connections now 450 byt i thing that if someone open 5 windows the same time and load content get banned..
