Dovecot authentication problem
Annatto
A user contacted me to say he couldn't connect to the email server, so I tried a test email account on his domain and found that dovecot accepted connections from telnet, but not from my email client:
telnet session which successfully authenticates:
Apr 8 14:35:52 xxx dovecot[13408]: auth-worker(13794): shadow(test@xxx): unknown user
Apr 8 14:35:52 xxx dovecot[13408]: auth-worker(13794): passwd(test@xxx): unknown user
Apr 8 14:35:52 xxx dovecot[13408]: pop3-login: Login: user=<test@xxx>, method=PLAIN, rip=xxx, lip=xxx, mpid=13795, session=<y2YLEIj2GgBSIOF5>
Apr 8 14:36:03 xxx dovecot[13408]: pop3(test@xxx): Disconnected: Logged out top=0/0, retr=0/0, del=0/3, size=151382, bytes=12/62
email client session which fails:
Apr 8 14:36:20 xxx dovecot[13408]: auth-worker(13794): shadow(test,xxx): unknown user
Apr 8 14:36:20 xxx dovecot[13408]: auth: Error: passwd-file(test,xxx,<tJXEEYj2HwBSIOF5>): stat(/etc/virtual//passwd) failed: No such file or directory
I understand that the unknown user warnings are given because the user is not in 1 of the 2 dbs, but I'm puzzled by stat(/etc/virtual//passwd) - does this mean dovecot doesn't have the correct filename for the virtual passwd db?
Be grateful for any ideas or pointers
Well it seems to me that is missing the domain part.. maybe he didnt put the domain on login user?
Cause file should be located in /etc/virtual/DOMAIN/passwd and i suppose that domain is taken from username [email protected]
Can you check that?
Regards
Yes! I'd forgotten to include the domain part of the username.
