Dovecot problem
Lampje
Yesterday, I was testing my new nagios system. Therefore I stopped dovecot for testing. After the testing I will start dovecot, but there will be an error:
Starting dovecot: Fatal: listen(143) failed: Address already in use
I’m using DirectAdmin 1.31.4 and Debian 3.1. The error says that port 143 already used is. When I use: netstat –tulpen, I see that inetd used port 143:
tcp 0 0 0.0.0.0:143 0.0.0.0:* LISTEN 0 20219387 9239/inetd
Inetd has take over the port when dovecot was stoppig. Is that normally or I must think of a rootkit or hackingattempt?
Is this problem solved by a reboot? Or does the problem become then larger? Can I kill the pid from inetd? And start dovecot and start inetd after dovecot?
Sorry for my English..
Maybe you have some sort of imap server running from inetd. You should check your inetd config to make sure.
Either /etc/inetd.conf
or a file in folder
/etc/xinetd.d/
If you are worried about rootkit download and install rkhunter or chkrootkit.
