What is the problem?
Shutting down dovecot: [FAILED]
Starting dovecot: Error: Error in configuration file /etc/dovecot.conf line 3: Unknown setting: ssl_cert
Fatal: Invalid configuration in /etc/dovecot.conf
## Dovecot 2.0 configuration file
ssl_cert = </etc/httpd/conf/ssl.crt/server.crt
ssl_key = </etc/httpd/conf/ssl.key/server.key
ssl_cipher_list = ALL:!ADH:RC4+RSA:+HIGH:+MEDIUM:-LOW:-SSLv2:-EXP
disable_plaintext_auth = no
## Login processes
listen = *
default_login_user = dovecot
login_greeting = Dovecot DA ready.
service imap-login {
inet_listener imap {
#port = 143
inet_listener imaps {
#port = 993
#ssl = yes
# Number of connections to handle before starting a new process. Typically
# the only useful values are 0 (unlimited) or 1. 1 is more secure, but 0
# is faster. <doc/wiki/LoginProcess.txt>
#service_count = 1
# Number of processes to always keep waiting for more connections.
#process_min_avail = 0
# If you set service_count=0, you probably need to grow this.
#vsz_limit = 64M
"/etc/dovecot.conf" 270L, 7951C
## Login processes
listen = *
#port = 143
#port = 993
#ssl = yes
#service_count = 1
#vsz_limit = 64M
