I have used ELS on my Linux VPS (CentOS)
I'm trying to use the ELS script. Firstly, I installed APC and there was a problem. This was fixed by changing a path in php.ini.
Second, I used ELS to install APF. It appeared to install fine, but when I run APF I get the following:
Could someone tell me how I can fix this?
Thanks,
T.
[root@server ~]#apf
: command not foundline 13:
: command not foundline 21:
: command not foundline 24:
: command not foundline 28:
: command not foundline 30:
: command not foundline 34:
: command not foundline 40:
: command not foundline 52:
: command not foundline 58:
: command not foundline 66:
: command not foundline 72:
: command not foundline 78:
: command not foundline 83:
: command not foundline 89:
: command not foundline 93:
: command not foundline 100:
: command not foundline 113:
: command not foundline 118:
: command not foundline 127:
: command not foundline 132:
: command not foundline 136:
: command not foundline 140:
: command not foundline 144:
: command not foundline 149:
: command not foundline 159:
: command not foundline 167:
: command not foundline 173:
: command not foundline 181:
: command not foundline 187:
: command not foundline 191:
: command not foundline 195:
: command not foundline 200:
: command not foundline 206:
: command not foundline 209:
: command not foundline 212:
: command not foundline 215:
: command not foundline 218:
: command not foundline 221:
: command not foundline 224:
: command not foundline 229:
: command not foundline 235:
: command not foundline 241:
: command not foundline 247:
: command not foundline 255:
: command not foundline 262:
: command not foundline 268:
: command not foundline 275:
: command not foundline 282:
: command not foundline 288:
: command not foundline 295:
: command not foundline 300:
: command not foundline 304:
: command not foundline 309:
: command not foundline 314:
: command not foundline 321:
: command not foundline 333:
: command not foundline 342:
: command not foundline 351:
: command not foundline 355:
: command not foundline 365:
: command not foundline 369:
: command not foundline 372:
: command not foundline 376:
: command not foundline 390:
: command not foundline 393:
: command not foundline 396:
: command not foundline 399:
: command not foundline 403:
: command not foundline 415:
: command not foundline 418:
: command not foundline 421:
: command not foundline 432:
: command not foundline 435:
: command not foundline 444:
: command not foundline 445:
: command not foundline 446:
: command not foundline 447:
: command not foundline 453:
: command not foundline 454:
: command not foundline 455:
: command not foundline 456:
: command not foundline 462:
: command not foundline 463:
: command not foundline 464:
: command not foundline 465:
: command not foundline 473:
: command not foundline 475:
: command not foundline 476:
: command not foundline 485:
: command not foundline 486:
: command not foundline 487:
: command not foundline 488:
: command not foundline 498:
: command not foundline 499:
: command not foundline 500:
: command not foundline 501:
: command not foundline 502:
: command not foundline 503:
: command not foundline 504:
: command not foundline 510:
: command not foundline 514:
: command not foundline 519:
: command not foundline 523:
: command not foundline 526:
: command not foundline 530:
: command not foundline 534:
: command not foundline 538:
: No such file or directory: /etc/apf
APF version 9.6 <[email protected]>
Copyright (C) 1999-2007, R-fx Networks <[email protected]>
Copyright (C) 2007, Ryan MacDonald <[email protected]>
This program may be freely redistributed under the terms of the GNU GPL
GNU bash, version 3.2.25(1)-release (x86_64-redhat-linux-gnu)
These shell commands are defined internally. Type `help' to see this list.
Type `help name' to find out more about the function `name'.
Use `info bash' to find out more about the shell in general.
Use `man -k' or `info' to find out more about commands not in this list.
A star (*) next to a name means that the command is disabled.
JOB_SPEC [&] (( expression ))
. filename [arguments] :
[ arg... ] [[ expression ]]
alias [-p] [name[=value] ... ] bg [job_spec ...]
bind [-lpvsPVS] [-m keymap] [-f fi break [n]
builtin [shell-builtin [arg ...]] caller [EXPR]
case WORD in [PATTERN [| PATTERN]. cd [-L|-P] [dir]
command [-pVv] command [arg ...] compgen [-abcdefgjksuv] [-o option
complete [-abcdefgjksuv] [-pr] [-o continue [n]
declare [-afFirtx] [-p] [name[=val dirs [-clpv] [+N] [-N]
disown [-h] [-ar] [jobspec ...] echo [-neE] [arg ...]
enable [-pnds] [-a] [-f filename] eval [arg ...]
exec [-cl] [-a name] file [redirec exit [n]
export [-nf] [name[=value] ...] or false
fc [-e ename] [-nlr] [first] [last fg [job_spec]
for NAME [in WORDS ... ;] do COMMA for (( exp1; exp2; exp3 )); do COM
function NAME { COMMANDS ; } or NA getopts optstring name [arg]
hash [-lr] [-p pathname] [-dt] [na help [-s] [pattern ...]
history [-c] [-d offset] [n] or hi if COMMANDS; then COMMANDS; [ elif
jobs [-lnprs] [jobspec ...] or job kill [-s sigspec | -n signum | -si
let arg [arg ...] local name[=value] ...
logout popd [+N | -N] [-n]
printf [-v var] format [arguments] pushd [dir | +N | -N] [-n]
pwd [-LP] read [-ers] [-u fd] [-t timeout] [
readonly [-af] [name[=value] ...] return [n]
select NAME [in WORDS ... ;] do CO set [--abefhkmnptuvxBCHP] [-o opti
shift [n] shopt [-pqsu] [-o long-option] opt
source filename [arguments] suspend [-f]
test [expr] time [-p] PIPELINE
times trap [-lp] [arg signal_spec ...]
true type [-afptP] name [name ...]
typeset [-afFirtx] [-p] name[=valu ulimit [-SHacdfilmnpqstuvx] [limit
umask [-p] [-S] [mode] unalias [-a] name [name ...]
unset [-f] [-v] [name ...] until COMMANDS; do COMMANDS; done
variables - Some variable names an wait [n]
while COMMANDS; do COMMANDS; done { COMMANDS ; }
Thanks,
T.
