Email Connection Problem
mmsitech
I can't receive mail from any email accounts. I can send them fine. But when I reply to them to see if it can receive, I get nothing. Not even any errors. Is there an error log somewhere I can read???
I also created a catch all to an external account "[email protected]" to make sure the server was talking.
Then I sent an email to "[email protected]" and it was routed to the catchall just fine. So the machine is communicating and processing the mail, I can't can't access it'
From reading the other posts... I also stopped iptables and restarted exim.
anyone have any other ideas???
server is nitto1320updates.com/63.161.166.80 (This IP is different from my main server IP that I installed DA with... Does this matter?)
Hard to say for sure what's going on...
You can check the logs:
for exim:
/var/log/exim/mainlog
for vm-pop3d:
/var/log/maillog
/var/log/messages
But if no error messages are being generated, I think it might be a simple issue of a forwarder or catch-all being setup incorrectly, or a typo?... It might be somthing more complicated, but I can't really say.
If you want me to have a look, send your root info, as well as the email address you are referring to.
FYI for anyone else, the directory /var/spool/virtual/nitto1320updates.com didn't exist, so exim wasn't able to send the mail there.
