I am trying to enable spamassassin learn as documented https://docs.directadmin.com/other-.../incoming-spam.html#how-to-teach-spamassassin
I am having some problems.
1. There is no sucs file as /usr/local/directadmin/custombuild/custom/systemd/spamassassin.service So i've modified the /etc/systemd/system/spamassassin.service file and add -l flag.
2. There is no directory at "For this edit to persist after updates, copy it to /usr/local/directadmin/custombuild/custom/dovecot/conf/". There is also no custom directory under /usr/local/directadmin/custombuild. So i created and copy the file.
The main problem is below:
3. I've created /usr/local/bin/dovecot-sieve/report-spam.sieve file as documented and when i run the command sievec report-spam.sieve it gives the error below:
The content of the file report-spam.sieve is below as documented:
Operating System: Ubuntu 20.04 LTS
DirectAdmin: 1.63.5
UPDATE:
Same error occurs after running "sievec report-ham.sieve" command
How can i enable sa-learn?
Thank you
report-spam: line 1: error: require command: unknown Sieve capability `vnd.dovecot.pipe'.
report-spam: line 1: error: require command: unknown Sieve capability `imapsieve'.
report-spam: line 7: error: unknown command 'pipe' (only reported once at first occurrence).
report-spam: error: validation failed.
sievec(root): Fatal: failed to compile sieve script 'report-spam.sieve'
require ["vnd.dovecot.pipe", "copy", "imapsieve", "environment", "variables"];
if environment :matches "imap.user" "*" {
set "username" "${1}";
pipe :copy "sa-learn-spam.sh" [ "${username}" ];
DirectAdmin: 1.63.5
UPDATE:
Thank you
