Error with system Quotas setquota: Mountpoint (or device) / not found or has no quota
xuancong6000
when I creat host from RSL it appear one error: "Error with system Quotas setquota: Mountpoint (or device) / not found or has no quota enabled. setquota: Not all specified mountpoints are using quota. Debug Guide"
this is my /etc/fstab: "none /dev/pts devpts rw,gid=5,mode=620 0 0"
Please help me fix the problem thanks
another one I want to setup SSL certificate to my domain how can I creat delicate IP for my domain from "IP Management" thanks alot
What part can you not do? Do you have quotas turned on in your OS? Do the various quota commands work when called directly from the root shell?
sorry i can't do it:( could you help me step by step
As soon as your /etc/fstab contains only one line with
you are probably running a OpenVZ container there (i.e. VPS) in this case you should ask your hosting provider (a company from which you bought a VPS) to enable Second Level Quotas support, without that you won't be able to use quotas on your virtual server.
