[EXIM 4.68] Problem with CentOS5
Randy
The Netherlands
Yust updated Exim to 4.68 on two boxes running CentOS5, and it went wrong. Someone familiar with the error below? I tried to remove "/var/run/exim/pid" and "/var/lock/subsys/exim".
Boxes are P4-2400 and Athlon 2600.
awk '{ print ($1+1) }' cnumber.h > cnumber.temp
rm -f cnumber.h; mv cnumber.temp cnumber.h
gcc version.c
rm -f exim
gcc -o exim
rfc2047.o: In function `rfc2047_decode2':
rfc2047.c:(.text+0x395): undefined reference to `libiconv_open'
rfc2047.c:(.text+0x45a): undefined reference to `libiconv'
rfc2047.c:(.text+0x539): undefined reference to `libiconv_close'
collect2: ld returned 1 exit status
make[1]: *** [exim] Error 1
make[1]: Leaving directory `/usr/local/updatescript/exim-4.68/build-Linux-i386'
make: *** [go] Error 2
Installation directory is /usr/sbin
*** /usr/local/updatescript/exim-4.68/build-Linux-i386/exim does not exist or is empty
*** Have you built Exim successfully?
*** Exim installation failed ***
make: *** [install] Error 1
cp: cannot stat `/usr/sbin/exim-4.68-1': No such file or directory
chmod: cannot access `/usr/sbin/exim': No such file or directory
Shutting down exim:
Starting exim: /etc/init.d/exim: line 30: /usr/sbin/exim: No such file or directory
Exim update done
[root@server78 updatescript]#
Quickfix: (CentOS 5)
cd ~
wget http://files.directadmin.com/services/es_5.0/da_exim-4.68-1.i386.rpm
rpm -Uvh --force --nodeps da_exim-4.68-1.i386.rpm
service exim start
>> exim works. Use dovecot? >> time to patch
./build todovecot [enter, enter, enter]
>> Restart dovecot manualy if the script doesnt
service dovecot restart
Done.
Weal, i suppose there is something wront while doing a dirchange in your script?
Or, just edit Local/Makefile, add these lines:
HAVE_ICONV=yes
CFLAGS=-O -I/usr/local/include
EXTRALIBS_EXIM=-L/usr/local/lib -liconv
And run:
make
make install
I have some troblesw with exim, i try to upgrade from 4.67 to 4.68, i use update.script, but i have some problem.
My Os is CentOS 4.5
The error is:
[root@s1 ~]#
[root@s1 ~]#
[root@s1 ~]# *** /usr/local/updatescript/exim-4.68/build-Linux-i386/exim does not exist or is empty
-bash: bill: command not found
[root@s1 ~]# *** Have you built Exim successfully?
[root@s1 ~]# *** Exim installation failed ***
[root@s1 ~]# make: *** [install] Error 1
-bash: make:: command not found
[root@s1 ~]# cp: cannot stat `/usr/sbin/exim-4.68-1': No such file or directory
> Shutting down exim:
Now the exim is down, : [root@s1 build-Linux-i386]# /etc/init.d/exim start
Also i try to upgrade thys . :
rpm -U da_exim-4.68-1.i386.rpm
file /etc/aliases from install of da_exim-4.68-1 conflicts with file from package setup-2.5.37-1.3
Have any sugestion?
Eduard.
The problem is solved,
HTML:
[root@s1 install]# /etc/init.d/exim start
Starting exim:
[root@s1 install]# /etc/init.d/exim status
exim (pid 3411 3401) is running...
HTML:
Starting exim:
Finally someone posted how they solved it when its resolved! :)
Hello
If i now the anser and is the best answer is post on forum.
Eduard
