exim clamav problem after upgrade
CentOS5
After upgrading clamav on my freebsd 5.4 server yesterday i get the following
malware acl condition: clamd: unable to connect to UNIX socket /var/run/clamav/clamd (Connection refused)
I have killed the clamav that was running,restarted it, restared exim , every works fine for about 30 min and then it all falls over again, no mail in or out and same message as above. I have removed clamav from exim.conf as this is driving me mad, anyone seen this and know how to fix it.
freebsd 5.4
clamav-0.93.1_2
exim 4.69
So does clamav crash or what?
Is there any errors in /var/log/clamav/clamd.log
Log size = 104858047, max = 104857600
LOGGING DISABLED (Maximal log file size exceeded).
Log size = 104858136, max = 104857600
mail#
and checked and logfile is 100m????? never had this problem before, going to set to 0 in clamd.conf
UPDATE
30 min later and it all stopped again, removed again frm exim.conf, so nothing to do with the log size.
clamd.log shows
Mon Jun 30 16:54:16 2008 -> No stats for Database check - forcing reload
Mon Jun 30 16:54:16 2008 -> Reading databases from /var/db/clamav
and exim panic log shows
Fixed
cd /usr/ports/security/clamav
change in Makefile
--enable-gethostbyname_r \
to
--disable-gethostbyname_r \
AND
change
PTHREAD_LIBS= -lthr
TO
PTHREAD_LIBS= -pthread
for freebsd5.4 on
The ltht was the main problem, it kept crashing clamav, works fine on my fbsd6 box but on 5.4 it had to be changed to -pthread.
