Exim domainowners Auth problem
davidb
The "real" user accounts (i.e. domainowners) no longer are able to send with auth turned on.
RH9 based platform
Is there any kind of error message? I'd also check /var/log/exim/mainlog immediately after a failure to see what gets logged.
Finally got a chance to look back on this for a few..
2006-11-14 09:01:05 plain authenticator failed for ip-207-145-49-78.sjc.megapath.net ([10.5.50.245]) [207.145.49.78]: 535 Incorrect authentication data (set_id=byte)
2006-11-14 09:01:05 login authenticator failed for ip-207-145-49-78.sjc.megapath.net ([10.5.50.245]) [207.145.49.78]: 535 Incorrect authentication data (set_id=byte)
Those are the errors.. The exim.conf is custom as I use an off-box spam solution. If you guys are willing to take a look, I will post it. I imagine I may have something screwed there. I haven't changed anything in the exim.pl
here's my exim.conf
local_interfaces = 0.0.0.0.25 : 0.0.0.0.10025 : 0.0.0.0.2525
primary_hostname = lh1.web-host.net
perl_startup = do '/etc/exim.pl'
system_filter = /etc/system_filter.exim
message_size_limit = 20M
smtp_receive_timeout = 5m
smtp_accept_max = 100
message_body_visible = 3000
helo_allow_chars = _
log_selector = \
+delivery_size \
+sender_on_delivery \
+received_recipients \
+received_sender \
+smtp_confirmation \
+subject \
+smtp_incomplete_transaction \
-dnslist_defer \
-host_lookup_failed \
-queue_run \
-rejected_header \
-retry_defer \
-skip_delivery
syslog_duplication = false
acl_smtp_rcpt = check_recipient
acl_smtp_data = check_message
domainlist blacklist_domains = lsearch;/etc/virtual/blacklist_domains
domainlist whitelist_from = lsearch;/etc/virtual/whitelist_from
domainlist local_domains = lsearch;/etc/virtual/domains
domainlist relay_domains = lsearch;/etc/virtual/domains : localhost
domainlist use_rbl_domains = lsearch;/etc/virtual/domains
hostlist relay_hosts = net-lsearch;/etc/virtual/pophosts : 127.0.0.1 : 208.65.113.140 : 208.65.113.141 : 208.65.113.142
hostlist auth_relay_hosts = *
allow_domain_literals = false
never_users = root
host_lookup = *
rfc1413_hosts = *
rfc1413_query_timeout = 0s
ignore_bounce_errors_after = 2d
timeout_frozen_after = 5d
trusted_users = mail:majordomo:apache:diradmin
tls_certificate = /etc/exim.cert
tls_privatekey = /etc/exim.key
tls_advertise_hosts = *
begin acl
check_recipient:
accept hosts = :
deny domains = +local_domains
local_parts = ^[.] : ^.*[@%!/|]
deny domains = !+local_domains
local_parts = ^[./|] : ^.*[@%!] : ^.*/\\.\\./
accept domains = +whitelist_from
accept local_parts = postmaster
accept local_parts = abuse
accept local_parts = hostmaster
domains =+local_domains
accept local_parts = support
domains = web-host.net
deny message = You may think you're legal but you're still an unwanted spammer
domains = +use_rbl_domains
sender_domains = +blacklist_domains
require verify = sender
dnslists = sbl.spamhaus.org : \
relays.ordb.org : \
dnsbl.sorbs.net=127.0.0.5
hosts = !+relay_hosts
domains =+use_rbl_domains
!authenticated = *
dnslists = cbl.abuseat.org : \
dnsbl.sorbs.net!=127.0.0.6
dnslists = rhsbl.sorbs.net/$sender_address_domain
accept domains = +local_domains
endpass
verify = recipient
accept domains = +relay_domains
endpass
verify=recipient
accept hosts = +relay_hosts
accept hosts = +auth_relay_hosts
endpass
message = authentication required
authenticated = *
deny message = relay not permitted
check_message:
accept
begin authenticators
plain:
driver = plaintext
public_name = PLAIN
server_condition = "${perl{smtpauth}}"
server_set_id = $2
login:
driver = plaintext
public_name = LOGIN
server_prompts = "Username:: : Password::"
server_set_id = $1
begin routers
lookuphost:
driver = dnslookup
domains = ! +local_domains
ignore_target_hosts = 127.0.0.0/8
condition = "${perl{check_limits}}"
transport = remote_smtp
no_more
majordomo_private_vrfy:
driver = redirect
allow_defer
allow_fail
condition = "${if eq {$received_protocol} {local} \
{true} {false} }"
data = ${if exists{/etc/virtual/${domain}/majordomo/private.aliases}{${lookup{$local_part}lsearch{/etc/virtual/${domain}/majordomo/private.aliases}}}}
domains = lsearch;/etc/virtual/domainowners
verify_only
pass_router = majordomo_private
majordomo_aliases_vrfy:
driver = redirect
allow_defer
allow_fail
data = ${if exists{/etc/virtual/${domain}/majordomo/list.aliases}{${lookup{$local_part}lsearch{/etc/virtual/${domain}/majordomo/list.aliases}}}}
verify_only
pass_router = majordomo_aliases
check_system_aliases:
driver = redirect
allow_fail
allow_defer
data = ${lookup{$local_part}lsearch{/etc/aliases}}
verify_only
pass_router = amavis
virtual_aliases_nostar_vrfy:
driver = redirect
condition = "${if or {{eq {$interface_port}{10025}} \
{eq {$received_protocol}{spam-scanned}} \
{eq {$sender_address}{}} \
}{0}{1}}"
allow_defer
allow_fail
data = ${if exists{/etc/virtual/${domain}/aliases}{${lookup{$local_part}lsearch{/etc/virtual/${domain}/aliases}}}}
verify_only
virtual_user_vrfy:
driver = accept
condition = ${if eq {}{${if exists{/etc/virtual/${domain}/passwd}{${lookup{$local_part}lsearch{/etc/virtual/${domain}/passwd}}}}}{no}{yes}}
verify_only
virtual_aliases_vrfy:
driver = redirect
allow_defer
allow_fail
data = ${if exists{/etc/virtual/$domain/aliases}{${lookup{$local_part}lsearch*{/etc/virtual/$domain/aliases}}}}
verify_only
check_localuser:
driver = accept
check_local_user
verify_only
failed_address_router:
driver = accept
verify_only
fail_verify
amavis:
driver = manualroute
{eq {$received_protocol}{spam-scanned}}\
{eq {$received_protocol}{local}}\
}{0}{1} }"
transport = amavis
route_list = "* mailguard.web-host.net byname"
self = send
dnslookup:
driver = dnslookup
ignore_target_hosts = 0.0.0.0 : 127.0.0.0/8
no_more
majordomo_aliases:
driver = redirect
allow_defer
allow_fail
file_transport = address_file
group = daemon
pipe_transport = majordomo_pipe
retry_use_local_part
no_rewrite
user = majordomo
majordomo_private:
driver = redirect
allow_defer
allow_fail
condition = "${if or { {eq {$received_protocol} {local}} \
{eq {$received_protocol} {spam-scanned}} } {true} {false} }"
group = daemon
user = majordomo
domain_filter:
driver = redirect
allow_filter
no_check_local_user
condition = "${if exists{/etc/virtual/${domain}/filter}{yes}{no}}"
user = "mail"
file = /etc/virtual/${domain}/filter
pipe_transport = virtual_address_pipe
no_verify
uservacation:
driver = accept
condition = ${lookup{$local_part} lsearch {/etc/virtual/${domain}/vacation.conf}{yes}{no}}
require_files = /etc/virtual/${domain}/reply/${local_part}.msg
transport = uservacation
unseen
userautoreply:
driver = accept
condition = ${lookup{$local_part} lsearch {/etc/virtual/${domain}/autoresponder.conf}{yes}{no}}
transport = userautoreply
unseen
virtual_aliases_nostar:
driver = redirect
allow_defer
allow_fail
group = mail
unseen
virtual_user:
driver = accept
group = mail
transport = virtual_localdelivery
virtual_aliases:
driver = redirect
allow_defer
allow_fail
group = mail
userforward:
driver = redirect
allow_filter
check_ancestor
check_local_user
no_expn
file = $home/.forward
pipe_transport = address_pipe
reply_transport = address_reply
no_verify
system_aliases:
driver = redirect
allow_defer
allow_fail
localuser:
driver = accept
check_local_user
condition = "${if eq {$domain} {$primary_hostname} {yes} {no}}"
transport = local_delivery
begin transports
amavis:
driver = smtp
port = 10024
spamcheck:
driver = pipe
batch_max = 100
command = /usr/sbin/exim -oMr spam-scanned -bS
current_directory = "/tmp"
group = mail
home_directory = "/tmp"
log_output
message_prefix =
message_suffix =
return_fail_output
no_return_path_add
transport_filter = /usr/bin/spamc -u ${lookup{$domain}lsearch*{/etc/virtual/domainowners}{$value}}
use_bsmtp
user = mail
majordomo_pipe:
driver = pipe
group = daemon
return_fail_output
user = majordomo
local_delivery:
driver = appendfile
delivery_date_add
envelope_to_add
file = /var/mail/$local_part
group = mail
mode = 0660
return_path_add
user = ${local_part}
virtual_localdelivery:
driver = appendfile
create_directory
delivery_date_add
directory_mode = 700
envelope_to_add
file = /var/spool/virtual/${domain}/${local_part}
group = mail
mode = 660
return_path_add
user = "${lookup{$domain}lsearch*{/etc/virtual/domainowners}{$value}}"
quota = ${if exists{/etc/virtual/${domain}/quota}{${lookup{$local_part}lsearch*{/etc/virtual/${domain}/quota}{$value}{0}}}{0}}
uservacation:
driver = autoreply
file = /etc/virtual/${domain}/reply/${local_part}.msg
from = "${local_part}@${domain}"
log = /etc/virtual/${domain}/reply/${local_part}.log
no_return_message
subject = "${if def:h_Subject: {Autoreply: $h_Subject:} {I am on vacation}}"
text = "\
------ ------\n\n\
This message was automatically generated by email software\n\
The delivery of your message has not been affected.\n\n\
------ ------\n\n"
to = "${sender_address}"
user = mail
userautoreply:
driver = autoreply
bcc = ${lookup{${local_part}} lsearch {/etc/virtual/${domain}/autoresponder.conf}{$value}}
no_return_message
subject = "${if def:h_Subject: {Autoreply: $h_Subject:} {Autoreply Message}}"
user = mail
remote_smtp:
driver = smtp
address_pipe:
driver = pipe
return_output
virtual_address_pipe:
driver = pipe
group = nobody
return_output
user = "${lookup{$domain}lsearch* {/etc/virtual/domainowners}{$value}}"
address_file:
driver = appendfile
delivery_date_add
envelope_to_add
return_path_add
address_reply:
driver = autoreply
begin retry
* * F,2h,15m; G,16h,1h,1.5; F,4d,8h
Nothing jumps out at me, but the only other thing I can think of that would cause system users to fail authentication, is a problem with the /home/${systemuser}/.shadow file. Each system user that needs to authenticate with exim needs to have a .shadow file in their home directory with group permissions of mail or exim or what ever group your exim runs with. It should contain a crypted password. If you need to create a .shadow file, run this perl script in the home directory of the system user.
#!/usr/bin/perl
$clearpwd=$ARGV[0];
open(OUTFILE,">.shadow")||die "Could not create file .shadow. $!\n";
@letters = ('A' .. 'Z', 'a' .. 'z', '0' .. '9', '/', '.');
$salt = $letters[rand@letters] . $letters[rand@letters];
$crptpwd=crypt($clearpwd,$salt);
print OUTFILE $crptpwd;
close(OUTFILE);
Then fix your permissions properly.
I put the .shadow file in the dir, but the problem still exists..
any more help?
this is driving me insane..
any more help?
Did you also make sure that exim has the ability to read that .shadow file? Make sure it is owned by user and group of mail, and have the permissions of 0640 (-rw-r-----).
I also assume you are using only the username as a login and not username@domainname, which would signal exim to look for this in the virtual passwd file.
Sure did.. Did I mention that sending works fine from squirrelmail?
This user used to work just fine btw...
