Hi gr8 ppl
Here is my situation:
I run:
Fedora core 5 (32)
CPU: Core Duo
RAM: 4GB
HDD: 6 units of HDD, SATA, RAIDed, 250GB each
DA
I only run FILE HOSTING SCRIPT which is of course resource consuming script but I recieve very high CPU load, anything else seems to be normal.
Httpd:
PHP.INI
Thats all I modifed, everything else remains default.
and this is my stats after TOP command:
why I get so many sleeping taks? what does it means? what would you recommend?
thank you in advance
I run:
Fedora core 5 (32)
CPU: Core Duo
RAM: 4GB
DA
Httpd:
Timeout 200
KeepAlive On
MaxKeepAliveRequests 80
KeepAliveTimeout 7
MinSpareServers 5
MaxSpareServers 10
MaxClients 2000
PHP.INI
max_execution_time = 360
max_input_time = 360
memory_limit = 32M
post_max_size = 2000M
upload_max_filesize = 1000M
default_socket_timeout = 360
Tasks: 291 total, 2 running, 289 sleeping, 0 stopped, 0 zombie
Cpu(s): 55.6% us, 22.2% sy, 0.0% ni, 11.1% id, 0.0% wa, 0.0% hi, 11.1% si,
Mem: 4126460k total, 3925804k used, 200656k free, 21728k buffers
Swap: 41928952k total, 144k used, 41928808k free, 3118812k cached
Unknown command - try 'h' for help
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
451 root 10 -5 0 0 0 S 0 0.0 24:49.86 md1_raid5
17152 mysql 15 0 122m 27m 3296 S 0 0.7 4:13.61 mysqld
193 root 15 0 0 0 0 S 0 0.0 1:19.30 kswapd0
462 root 15 0 0 0 0 S 0 0.0 1:01.54 kjournald
1869 named 15 0 52804 8268 2100 S 0 0.2 0:43.19 named
2724 root 0 -20 0 0 0 S 0 0.0 0:26.53 loop0
23697 nobody 15 0 17240 7116 2336 S 0 0.2 0:13.90 httpd
26459 nobody 15 0 17232 7108 2336 S 0 0.2 0:13.81 httpd
23820 nobody 15 0 17156 7032 2336 S 0 0.2 0:12.97 httpd
25516 nobody 15 0 17208 7100 2336 S 0 0.2 0:12.91 httpd
23658 nobody 15 0 17184 6660 1920 S 0 0.2 0:12.00 httpd
25601 nobody 15 0 17208 6684 1920 S 0 0.2 0:11.61 httpd
26905 nobody 15 0 17212 6688 1920 S 0 0.2 0:11.41 httpd
23656 nobody 15 0 17216 6692 1920 S 0 0.2 0:11.37 httpd
23743 nobody 15 0 17212 6692 1924 S 0 0.2 0:10.94 httpd
23826 nobody 15 0 17232 7112 2340 S 0 0.2 0:10.89 httpd
26067 nobody 15 0 17136 6612 1920 S 0 0.2 0:10.68 httpd
