Hi all,
Long (and hideously stupid) problem here.
I was running PHP 5.2.10. I wanted to upgrade to 5.3.9.
First off, I tried to upgrade PHP manually using the following steps:
It's worth noting at this point that I completely forgot I was using DirectAdmin
Upon suggestion of a friend I change the "yum.conf" to stop excluding php, mysql etc updates.
I then "yum update"d all.
I then individually "yum install php". Not long after, I "yum remove php-common" and "yum install mod_php".
Since then, my problems are as follows:
After all of that, I remembered that I use DirectAdmin and that I've probably killed off a lot of the DA-specific PHP and Apache config.
So, I tried to use "custombuild" to update. It seemed to do everything correctly but it hasn't made any difference; probably because it hasn't overwritten the incorrect httpd.conf files.
All in all, I've f0rked up pretty badly
Unfortunately I don't know anywhere near enough about Linux to fix it.
Do I simply need a DA-specific httpd.conf ? Does anyone have a copy of the default that I could try?
- Logged in as root
- wget the latest PHP installation
- tar zxvf php-.....gz
- cd php-....
- ./configure
- make
- apachectl stop
- make install
- apachectl start
- httpd wouldn't restart because of a "SSLEngine" error
- changed httpd.conf to a new one, wouldn't start because of "Invalid command 'Order', perhaps misspelled or defined by a module not included in the server configuration" error
- used a differend httpd.conf to get httpd working, but now I can't access /phpmyadmin or /dev/ (my wordpress install which uses htaccess heavily)
