Fedora core 2 installation problem
daride
When i started installing DA it showed up this:
Cannot find ip in the ./scripts/setup.txt file
## INSTALL_FAILED
## REPORT_END
I was thinking the problem was with the eth0 device name:
I use a custom eth0 device name I tought the name was vlan473
Ifconfig shows this up:
[root@serv-3-11-132 root]# ifconfig
vlan473 Link encap:Ethernet HWaddr 00:14:22:12:A5:B5
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:815186176 errors:0 dropped:0 overruns:0 frame:0
TX packets:129601792 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:1493158929 (1423.9 Mb) TX bytes:436456053 (416.2 Mb)
So what did i do wrong..is it something with the device name of eth0 or something else..
Thanks in progress
