S SoCal Verified User Joined May 13, 2007 Messages 24 May 18, 2007 #1 Hi, I am unable to change the permission of my files in filemanager, What s wrong with it, There is not a Tick enabled so i check or uncheck it. Am i missing something or is it a problem with DA? Thanks.
S SoCal Verified User Joined May 13, 2007 Messages 24 May 29, 2007 #2 Hi, Anybody please reply, I see my filed and i want to change permission from file manager, But the tick is disabled? How may i corrdct this thiung, Cpanel doesnt gave this problem.
nobaloney NoBaloney Internet Svcs - In Memoriam † Joined Jun 16, 2003 Messages 25,033 Location California May 29, 2007 #3 Is it your server? If so, you should shell into it, and post the output of ls -al for the files you can't change. If not you should contact your hosting company. Jeff
S SoCal Verified User Joined May 13, 2007 Messages 24 Jun 2, 2007 #4 Hi, I have root access. Here is ls-al of files: -rw-r--r-- 1 root root 972 May 21 10:55 article.php -rw-r--r-- 1 root root 2914 May 21 10:55 backend.php -rw-r--r-- 1 root root 4562 May 21 10:55 banner.php drwxr-xr-x 2 haryanajan haryanajan 4096 Jun 2 20:40 cgi-bin -rw-r--r-- 1 root root 54207 May 21 10:55 class2.php -rw-r--r-- 1 root root 10001 May 21 10:55 comment.php -rw-r--r-- 1 root root 4141 May 21 10:55 contact.php -rw-r--r-- 1 root root 2521 May 21 10:55 content.php -rw-r--r-- 1 root root 236 May 23 12:36 data.html -rw-r--r-- 1 root root 28588 May 21 10:55 download.php -rw-r--r-- 1 root root 331 May 24 06:14 download1.php -rw-r--r-- 1 root root 164 May 21 10:55 e107.htaccess drwxr-sr-x 4 root root 4096 May 21 10:26 e107_admin -rwxrwxrwx 1 root root 927 Jun 2 20:44 e107_config.php drwxr-sr-x 3 root root 4096 May 21 10:26 e107_docs drwxr-sr-x 13 root root 4096 May 21 10:27 e107_files drwxr-sr-x 6 root root 4096 May 21 10:29 e107_handlers drwxr-sr-x 14 root root 4096 May 21 12:58 e107_images drwxr-sr-x 3 root root 4096 May 21 10:38 e107_languages drwxrwxrwx 41 root root 4096 May 21 10:49 e107_plugins drwxrwxrwx 16 root root 4096 May 21 10:54 e107_themes -rw-r--r-- 1 root root 5514 May 21 10:55 email.php -rw-r--r-- 1 root root 2916 May 21 10:55 error.php -rw-r--r-- 1 root root 22486 May 21 10:55 favicon.ico -rw-r--r-- 1 root root 108 May 21 10:55 forum.php -rw-r--r-- 1 root root 256 May 21 10:55 forum_viewforum.php -rw-r--r-- 1 root root 260 May 21 10:55 forum_viewtopic.php -rw-r--r-- 1 root root 5066 May 21 10:55 fpw.php -rw-r--r-- 1 root root 2427 May 21 10:55 gsitemap.php -rw-r--r-- 1 root root 5472138 Jun 2 11:45 haryanaj.zip -rw-r--r-- 1 root root 170082 Jun 2 20:12 hjan.sql -rw-r--r-- 1 root root 10992164 Jun 2 20:36 hjan.zip drwxrwxrwx 2 root root 4096 May 25 13:01 images -rw-r--r-- 1 root root 3464 May 21 10:55 index.php -rw-r--r-- 1 root root 392 May 23 12:41 insert.php -rw-r--r-- 1 root root 118010 May 21 10:55 install -rw-r--r-- 1 root root 142 May 21 10:55 links.php -rw-r--r-- 1 root root 2497 May 21 10:55 login.php -rwxr-xr-x 1 haryanajan haryanajan 13954 Sep 16 2006 logo.jpg -rw-r--r-- 1 root root 957 May 21 10:55 membersonly.php -rw-r--r-- 1 root root 20754 May 21 10:55 news.php -rw-r--r-- 1 root root 10978 May 21 10:55 online.php -rw-r--r-- 1 root root 11830 May 21 10:55 page.php -rw-r--r-- 1 root root 3058 May 21 10:55 print.php -rw-r--r-- 1 root root 1523 May 21 10:55 rate.php -rw-r--r-- 1 root root 14465 May 21 10:55 request.php -rw-r--r-- 1 root root 130 May 21 10:55 robots.txt -rw-r--r-- 1 root root 1726 May 26 13:11 s.htm -rw-r--r-- 1 root root 1711 May 26 12:37 s.html -rw-r--r-- 1 root root 1639 May 26 12:40 s.php -rw-r--r-- 1 root root 19098 May 21 10:55 search.php -rw-r--r-- 1 root root 1721 May 26 12:25 searchtry1.php -rw-r--r-- 1 root root 26674 May 21 10:55 signup.php -rw-r--r-- 1 root root 1115 May 21 10:55 sitedown.php -rw-r--r-- 1 root root 830 May 21 10:55 subcontent.php -rw-r--r-- 1 root root 7879 May 21 10:55 submitnews.php -rw-r--r-- 1 root root 9210 May 21 10:55 top.php drwxr-sr-x 3 root root 4096 Jun 1 07:09 trial -rw-r--r-- 1 root root 747 May 22 11:20 try.php -rw-r--r-- 1 root root 6938 May 21 10:55 upload.php -rw-r--r-- 1 root root 342 May 24 05:57 upload1.html -rw-r--r-- 1 root root 671 May 24 05:57 upload1.php -rw-r--r-- 1 root root 4377 May 21 10:55 user.php -rw-r--r-- 1 root root 7487 May 21 10:55 userposts.php -rw-r--r-- 1 root root 13928 May 21 10:55 usersettings.php Please provide me solution, I will be very thanksful.
smtalk Administrator Staff member Joined Aug 22, 2006 Messages 9,328 Location LT, EU Jun 2, 2007 #5 Files are owned by root, FileManager can only reset ownership when the files are owned by apache. Do this in ssh: Code: chown -R haryanajan:haryanajan /home/haryanajan/domains/[B]domain[/B]/public_html Change domain to your domain name. Last edited: Jun 4, 2007
nobaloney NoBaloney Internet Svcs - In Memoriam † Joined Jun 16, 2003 Messages 25,033 Location California Jun 4, 2007 #6 And next time don't setup your domain as the root user . Jeff
S SoCal Verified User Joined May 13, 2007 Messages 24 Jun 9, 2007 #7 Hi, Thanks for the help I havent set the domain as root. I created a reseller and then set the domain in that reseller account. How may I change the default setting that domains not to be set as root users. By default my all domains show this same problem.
S SoCal Verified User Joined May 13, 2007 Messages 24 Jun 9, 2007 #8 Oops yeah maybe this problem happenned because i moved the files from other host and extracted the domain's files as a root user. Thanks smtalk and jlasman
nobaloney NoBaloney Internet Svcs - In Memoriam † Joined Jun 16, 2003 Messages 25,033 Location California Jun 10, 2007 #9 You've figured it out! And you're very welcome! Jeff
