Very small feature but very handy.
I am just use to a logic that if i right-click some file or folder row i get a menu. Would help a lot of users as well. At first, when i discovered the File Manager i did not understand how to open menu, so i figured out that pretty soon but i always need to hover that tiny file/folder name to get the menu open.
P.S. I am not very happy about that the menu and the left directory tree are black while file tree is white.
I feel like the left directory tree and the menu should be light/silver style if we for example will use the white skin and blackish if we use dark skin.
Also, the hovered menu should not use underline on hover, but should change the <li> background instead and maybe font should be little bit bigger.
Just for reference:
Just for reference:
