Filesystem problem
villah
We have DA running with storage of logs and sites on a different disk. This gave problems uploading files but that has been fixed in the latest version. This same problem still exists when uploading a new skin though:
Unable to move ../../../home/tmp/da_hermes.102.tar.gz5QvAsz to /var/home/admin/skins/Hermes_102/skin.tar.gz:
oldpath and newpath are not on the same filesystem.
Then did it reappear in 1.20.7?? :confused: That's the version we're running and where the problem occurs..
Ah.. skins... I thought you meant filemanager. Just had a look at the code and the skin uploader is still using the "rename" convention. I'll make the fix here for the next release.
