Welcome.
I have a problem with Firewall. During the connection and uploading files via FTP to the server, the connection was interrupted and since then it is not possible to access the server from outside the network only from the LAN. When the firewall is turned off, everything works as it should, but that's not the point.
When turning on the firewall, I have the following entries:
Please tell me what happened and how can I fix it quickly? Possibly what to put here to make everything work again as it should.
ConfigServer Security & Firewall - csf v14.10
Enabling csf...
csf: FASTSTART loading DROP no logging (IPv4)
csf: FASTSTART loading DROP no logging (IPv6)
LOG tcp opt -- in * out * 0.0.0.0/0 -> 0.0.0.0/0 limit: avg 30/min burst 5 LOG flags 0 level 4 prefix "Firewall: *TCP_IN Blocked* "
LOG tcp opt -- in * out * 0.0.0.0/0 -> 0.0.0.0/0 tcp flags:0x17/0x02 limit: avg 30/min burst 5 LOG flags 8 level 4 prefix "Firewall: *TCP_OUT Blocked* "
LOG udp opt -- in * out * 0.0.0.0/0 -> 0.0.0.0/0 limit: avg 30/min burst 5 LOG flags 0 level 4 prefix "Firewall: *UDP_IN Blocked* "
LOG udp opt -- in * out * 0.0.0.0/0 -> 0.0.0.0/0 limit: avg 30/min burst 5 LOG flags 8 level 4 prefix "Firewall: *UDP_OUT Blocked* "
LOG icmp opt -- in * out * 0.0.0.0/0 -> 0.0.0.0/0 limit: avg 30/min burst 5 LOG flags 0 level 4 prefix "Firewall: *ICMP_IN Blocked* "
LOG icmp opt -- in * out * 0.0.0.0/0 -> 0.0.0.0/0 limit: avg 30/min burst 5 LOG flags 8 level 4 prefix "Firewall: *ICMP_OUT Blocked* "
LOG tcp opt in * out * ::/0 -> ::/0 limit: avg 30/min burst 5 LOG flags 0 level 4 prefix "Firewall: *TCP6IN Blocked* "
LOG tcp opt in * out * ::/0 -> ::/0 tcp flags:0x17/0x02 limit: avg 30/min burst 5 LOG flags 8 level 4 prefix "Firewall: *TCP6OUT Blocked* "
LOG udp opt in * out * ::/0 -> ::/0 limit: avg 30/min burst 5 LOG flags 0 level 4 prefix "Firewall: *UDP6IN Blocked* "
LOG udp opt in * out * ::/0 -> ::/0 limit: avg 30/min burst 5 LOG flags 8 level 4 prefix "Firewall: *UDP6OUT Blocked* "
LOG icmpv6 opt in * out * ::/0 -> ::/0 limit: avg 30/min burst 5 LOG flags 0 level 4 prefix "Firewall: *ICMP6IN Blocked* "
LOG icmpv6 opt in * out * ::/0 -> ::/0 limit: avg 30/min burst 5 LOG flags 8 level 4 prefix "Firewall: *ICMP6OUT Blocked* "
DROP all opt -- in * out * 0.0.0.0/0 -> 0.0.0.0/0
REJECT all opt -- in * out * 0.0.0.0/0 -> 0.0.0.0/0 reject-with icmp-port-unreachable
DROP all opt in * out * ::/0 -> ::/0
REJECT all opt in * out * ::/0 -> ::/0 reject-with icmp6-port-unreachable
DENYOUT all opt -- in * out !lo 0.0.0.0/0 -> 0.0.0.0/0
DENYIN all opt -- in !lo out * 0.0.0.0/0 -> 0.0.0.0/0
ALLOWOUT all opt -- in * out !lo 0.0.0.0/0 -> 0.0.0.0/0
ALLOWIN all opt -- in !lo out * 0.0.0.0/0 -> 0.0.0.0/0
DENYOUT all opt in * out !lo ::/0 -> ::/0
DENYIN all opt in !lo out * ::/0 -> ::/0
ALLOWOUT all opt in * out !lo ::/0 -> ::/0
ALLOWIN all opt in !lo out * ::/0 -> ::/0
csf: FASTSTART loading Packet Filter (IPv4)
csf: FASTSTART loading Packet Filter (IPv6)
INVALID tcp opt -- in !lo out * 0.0.0.0/0 -> 0.0.0.0/0
INVALID tcp opt -- in * out !lo 0.0.0.0/0 -> 0.0.0.0/0
INVALID tcp opt in !lo out * ::/0 -> ::/0
INVALID tcp opt in * out !lo ::/0 -> ::/0
csf: IPSET creating set chain_DENY
csf: IPSET creating set chain_6_DENY
csf: FASTSTART loading csf.deny (IPv4)
csf: FASTSTART loading csf.deny (IPv6)
csf: FASTSTART loading csf.deny (IPSET)
DROP tcp opt -- in !lo out * 45.133.1.218 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.133.1.218 tcp dpt:587
DROP tcp opt -- in !lo out * 45.144.225.54 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.144.225.54 tcp dpt:25
DROP tcp opt -- in !lo out * 45.144.225.54 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.144.225.54 tcp dpt:465
DROP tcp opt -- in !lo out * 45.144.225.54 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.144.225.54 tcp dpt:587
DROP tcp opt -- in !lo out * 31.210.20.23 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.20.23 tcp dpt:25
DROP tcp opt -- in !lo out * 31.210.20.23 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.20.23 tcp dpt:465
DROP tcp opt -- in !lo out * 31.210.20.23 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.20.23 tcp dpt:587
DROP tcp opt -- in !lo out * 31.210.20.155 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.20.155 tcp dpt:25
DROP tcp opt -- in !lo out * 31.210.20.155 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.20.155 tcp dpt:465
DROP tcp opt -- in !lo out * 31.210.20.155 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.20.155 tcp dpt:587
DROP tcp opt -- in !lo out * 31.210.20.109 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.20.109 tcp dpt:25
DROP tcp opt -- in !lo out * 31.210.20.109 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.20.109 tcp dpt:465
DROP tcp opt -- in !lo out * 31.210.20.109 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.20.109 tcp dpt:587
DROP tcp opt -- in !lo out * 31.210.21.195 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.21.195 tcp dpt:25
DROP tcp opt -- in !lo out * 31.210.21.195 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.21.195 tcp dpt:465
DROP tcp opt -- in !lo out * 31.210.21.195 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.21.195 tcp dpt:587
DROP tcp opt -- in !lo out * 45.133.1.203 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.133.1.203 tcp dpt:25
DROP tcp opt -- in !lo out * 45.133.1.203 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.133.1.203 tcp dpt:465
DROP tcp opt -- in !lo out * 45.133.1.203 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.133.1.203 tcp dpt:587
DROP tcp opt -- in !lo out * 31.210.20.111 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.20.111 tcp dpt:25
DROP tcp opt -- in !lo out * 31.210.20.111 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.20.111 tcp dpt:465
DROP tcp opt -- in !lo out * 31.210.20.111 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.20.111 tcp dpt:587
DROP tcp opt -- in !lo out * 31.210.20.173 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.20.173 tcp dpt:25
DROP tcp opt -- in !lo out * 31.210.20.173 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.20.173 tcp dpt:465
DROP tcp opt -- in !lo out * 31.210.20.173 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.20.173 tcp dpt:587
DROP tcp opt -- in !lo out * 31.210.21.96 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.21.96 tcp dpt:25
DROP tcp opt -- in !lo out * 31.210.21.96 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.21.96 tcp dpt:465
DROP tcp opt -- in !lo out * 31.210.21.96 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.21.96 tcp dpt:587
DROP tcp opt -- in !lo out * 136.144.41.70 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 136.144.41.70 tcp dpt:25
DROP tcp opt -- in !lo out * 136.144.41.70 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 136.144.41.70 tcp dpt:465
DROP tcp opt -- in !lo out * 136.144.41.70 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 136.144.41.70 tcp dpt:587
DROP tcp opt -- in !lo out * 195.133.40.41 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 195.133.40.41 tcp dpt:25
DROP tcp opt -- in !lo out * 195.133.40.41 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 195.133.40.41 tcp dpt:465
DROP tcp opt -- in !lo out * 195.133.40.41 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 195.133.40.41 tcp dpt:587
DROP tcp opt -- in !lo out * 45.144.225.206 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.144.225.206 tcp dpt:25
DROP tcp opt -- in !lo out * 45.144.225.206 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.144.225.206 tcp dpt:465
DROP tcp opt -- in !lo out * 45.144.225.206 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.144.225.206 tcp dpt:587
DROP tcp opt -- in !lo out * 31.210.21.82 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.21.82 tcp dpt:25
DROP tcp opt -- in !lo out * 31.210.21.82 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.21.82 tcp dpt:465
DROP tcp opt -- in !lo out * 31.210.21.82 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.21.82 tcp dpt:587
DROP tcp opt -- in !lo out * 195.133.40.31 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 195.133.40.31 tcp dpt:25
DROP tcp opt -- in !lo out * 195.133.40.31 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 195.133.40.31 tcp dpt:465
DROP tcp opt -- in !lo out * 195.133.40.31 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 195.133.40.31 tcp dpt:587
DROP tcp opt -- in !lo out * 31.210.20.41 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.20.41 tcp dpt:25
DROP tcp opt -- in !lo out * 31.210.20.41 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.20.41 tcp dpt:465
DROP tcp opt -- in !lo out * 31.210.20.41 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.20.41 tcp dpt:587
DROP tcp opt -- in !lo out * 45.133.1.192 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.133.1.192 tcp dpt:25
DROP tcp opt -- in !lo out * 45.133.1.192 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.133.1.192 tcp dpt:465
DROP tcp opt -- in !lo out * 45.133.1.192 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.133.1.192 tcp dpt:587
DROP tcp opt -- in !lo out * 45.144.225.205 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.144.225.205 tcp dpt:25
DROP tcp opt -- in !lo out * 45.144.225.205 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.144.225.205 tcp dpt:465
DROP tcp opt -- in !lo out * 45.144.225.205 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.144.225.205 tcp dpt:587
DROP tcp opt -- in !lo out * 31.210.21.24 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.21.24 tcp dpt:25
DROP tcp opt -- in !lo out * 31.210.21.24 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.21.24 tcp dpt:465
DROP tcp opt -- in !lo out * 31.210.21.24 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.21.24 tcp dpt:587
DROP tcp opt -- in !lo out * 45.133.1.127 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.133.1.127 tcp dpt:25
DROP tcp opt -- in !lo out * 45.133.1.127 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.133.1.127 tcp dpt:465
DROP tcp opt -- in !lo out * 45.133.1.127 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.133.1.127 tcp dpt:587
DROP tcp opt -- in !lo out * 45.133.1.50 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.133.1.50 tcp dpt:25
DROP tcp opt -- in !lo out * 45.133.1.50 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.133.1.50 tcp dpt:465
DROP tcp opt -- in !lo out * 45.133.1.50 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.133.1.50 tcp dpt:587
DROP tcp opt -- in !lo out * 31.210.21.43 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.21.43 tcp dpt:25
DROP tcp opt -- in !lo out * 31.210.21.43 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.21.43 tcp dpt:465
DROP tcp opt -- in !lo out * 31.210.21.43 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.21.43 tcp dpt:587
DROP tcp opt -- in !lo out * 31.210.21.62 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.21.62 tcp dpt:25
DROP tcp opt -- in !lo out * 31.210.21.62 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.21.62 tcp dpt:465
DROP tcp opt -- in !lo out * 31.210.21.62 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.21.62 tcp dpt:587
DROP tcp opt -- in !lo out * 45.144.225.204 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.144.225.204 tcp dpt:25
DROP tcp opt -- in !lo out * 45.144.225.204 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.144.225.204 tcp dpt:465
DROP tcp opt -- in !lo out * 45.144.225.204 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.144.225.204 tcp dpt:587
DROP tcp opt -- in !lo out * 195.133.40.63 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 195.133.40.63 tcp dpt:25
DROP tcp opt -- in !lo out * 195.133.40.63 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 195.133.40.63 tcp dpt:465
DROP tcp opt -- in !lo out * 195.133.40.63 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 195.133.40.63 tcp dpt:587
DROP tcp opt -- in !lo out * 45.133.1.58 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.133.1.58 tcp dpt:25
DROP tcp opt -- in !lo out * 45.133.1.58 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.133.1.58 tcp dpt:465
DROP tcp opt -- in !lo out * 45.133.1.58 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.133.1.58 tcp dpt:587
DROP tcp opt -- in !lo out * 136.144.41.132 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 136.144.41.132 tcp dpt:25
DROP tcp opt -- in !lo out * 136.144.41.132 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 136.144.41.132 tcp dpt:465
DROP tcp opt -- in !lo out * 136.144.41.132 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 136.144.41.132 tcp dpt:587
DROP tcp opt -- in !lo out * 31.210.20.54 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.20.54 tcp dpt:25
DROP tcp opt -- in !lo out * 31.210.20.54 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.20.54 tcp dpt:465
DROP tcp opt -- in !lo out * 31.210.20.54 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 31.210.20.54 tcp dpt:587
DROP tcp opt -- in !lo out * 45.133.1.214 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.133.1.214 tcp dpt:25
DROP tcp opt -- in !lo out * 45.133.1.214 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.133.1.214 tcp dpt:465
DROP tcp opt -- in !lo out * 45.133.1.214 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.133.1.214 tcp dpt:587
DROP tcp opt -- in !lo out * 37.0.10.4 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 37.0.10.4 tcp dpt:25
DROP tcp opt -- in !lo out * 37.0.10.4 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 37.0.10.4 tcp dpt:465
DROP tcp opt -- in !lo out * 37.0.10.4 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 37.0.10.4 tcp dpt:587
DROP tcp opt -- in !lo out * 45.9.20.15 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.9.20.15 tcp dpt:25
DROP tcp opt -- in !lo out * 45.9.20.15 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.9.20.15 tcp dpt:465
DROP tcp opt -- in !lo out * 45.9.20.15 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.9.20.15 tcp dpt:587
DROP tcp opt -- in !lo out * 193.56.29.219 -> 0.0.0.0/0 tcp dpt:25
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 193.56.29.219 tcp dpt:25
DROP tcp opt -- in !lo out * 193.56.29.219 -> 0.0.0.0/0 tcp dpt:465
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 193.56.29.219 tcp dpt:465
DROP tcp opt -- in !lo out * 193.56.29.219 -> 0.0.0.0/0 tcp dpt:587
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 193.56.29.219 tcp dpt:587
DROP tcp opt -- in !lo out * 23.148.145.71 -> 0.0.0.0/0 tcp dpt:20
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 23.148.145.71 tcp dpt:20
DROP tcp opt -- in !lo out * 23.148.145.71 -> 0.0.0.0/0 tcp dpt:21
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 23.148.145.71 tcp dpt:21
DROP tcp opt -- in !lo out * 45.155.204.190 -> 0.0.0.0/0 tcp dpt:110
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.155.204.190 tcp dpt:110
DROP tcp opt -- in !lo out * 45.155.204.190 -> 0.0.0.0/0 tcp dpt:143
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.155.204.190 tcp dpt:143
DROP tcp opt -- in !lo out * 45.155.204.190 -> 0.0.0.0/0 tcp dpt:993
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.155.204.190 tcp dpt:993
DROP tcp opt -- in !lo out * 45.155.204.190 -> 0.0.0.0/0 tcp dpt:995
LOGDROPOUT tcp opt -- in * out !lo 0.0.0.0/0 -> 45.155.204.190 tcp dpt:995
ACCEPT all opt -- in !lo out * 10.1.1.147 -> 0.0.0.0/0
ACCEPT all opt -- in * out !lo 0.0.0.0/0 -> 10.1.1.147
csf: IPSET creating set chain_ALLOW
csf: IPSET creating set chain_6_ALLOW
csf: FASTSTART loading csf.allow (IPv4)
csf: FASTSTART loading csf.allow (IPv6)
csf: FASTSTART loading csf.allow (IPSET)
ACCEPT icmp opt -- in !lo out * 0.0.0.0/0 -> 0.0.0.0/0 icmptype 8 limit: avg 1/sec burst 5
LOGDROPIN icmp opt -- in !lo out * 0.0.0.0/0 -> 0.0.0.0/0 icmptype 8
ACCEPT icmp opt -- in * out !lo 0.0.0.0/0 -> 0.0.0.0/0
ACCEPT icmpv6 opt in !lo out * ::/0 -> ::/0
ACCEPT icmpv6 opt in * out !lo ::/0 -> ::/0
ACCEPT all opt -- in !lo out * 0.0.0.0/0 -> 0.0.0.0/0 ctstate RELATED,ESTABLISHED
ACCEPT all opt -- in * out !lo 0.0.0.0/0 -> 0.0.0.0/0 ctstate RELATED,ESTABLISHED
ACCEPT all opt in !lo out * ::/0 -> ::/0 ctstate RELATED,ESTABLISHED
ACCEPT all opt in * out !lo ::/0 -> ::/0 ctstate RELATED,ESTABLISHED
csf: FASTSTART loading TCP_IN (IPv4)
csf: FASTSTART loading TCP6_IN (IPv6)
csf: FASTSTART loading TCP_OUT (IPv4)
csf: FASTSTART loading TCP6_OUT (IPv6)
csf: FASTSTART loading UDP_IN (IPv4)
csf: FASTSTART loading UDP6_IN (IPv6)
csf: FASTSTART loading UDP_OUT (IPv4)
csf: FASTSTART loading UDP6_OUT (IPv6)
ACCEPT all opt -- in lo out * 0.0.0.0/0 -> 0.0.0.0/0
ACCEPT all opt -- in * out lo 0.0.0.0/0 -> 0.0.0.0/0
LOGDROPOUT all opt -- in * out !lo 0.0.0.0/0 -> 0.0.0.0/0
LOGDROPIN all opt -- in !lo out * 0.0.0.0/0 -> 0.0.0.0/0
ACCEPT all opt in lo out * ::/0 -> ::/0
ACCEPT all opt in * out lo ::/0 -> ::/0
LOGDROPOUT all opt in * out !lo ::/0 -> ::/0
LOGDROPIN all opt in !lo out * ::/0 -> ::/0
SMTPOUTPUT all opt -- in * out * 0.0.0.0/0 -> 0.0.0.0/0
SMTPOUTPUT all opt in * out * ::/0 -> ::/0
csf: FASTSTART loading SMTP Block (IPv4)
csf: FASTSTART loading SMTP Block (IPv6)
csf: FASTSTART loading DNS (IPv4)
csf: FASTSTART loading DNS (IPv6)
