freetype problems...
alphaxs
Brummen
So i've got a machine with this configuration:
FreeBSD 5.1 with latest update of DA.
GD (stable) 1.8.4-6
and two packages of freetype (don't know how.. but that's what i see)
freetype 1.3.1-2
freetype2-2.1.4_1
info file: http://www.alphaxs2.nl/info.php
so the problem is: i need freetype support fo a customer wich is running gfxpoll.
But i can't make it work, did tried almost everything.
Did tried to install the package with pkg_add -r freetype (and tried with freetype2 and with whole version)
did go well, but still doesn't work, so freetype was'nt installed?
well ok, tried to compile gd with freetype.. tried it with just --with-freetype. (and on and on...)
tried to set it manualy in configure.php
tried it with ./configure --with-freetype2 :S
nothing seems to work.. so is there someone who has or had the same Or near) configuration, and which could get me trough to this???
regards,
I can't access the info.php file: is your problem solved yet? Otherwise I can help you because I had the same problem.
En ik spreek ook Nederlands ;)
