FTP Help
darky88
Hello.
I Own A VPS Server.
When I Try To Login To The FTP Its Stoping And I Have An Error.
Here What I See:
reply: ‎‪220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
reply: ‎‪220-You are user number 1 of 50 allowed.
reply: ‎‪220-Local time is now 02:20. Server port: 21.
reply: ‎‪220 You will be disconnected after 15 minutes of inactivity.
cmd: ‎‪USER ****
reply: ‎‪331 User **** OK. Password required
cmd: ‎‪PASS ********
reply: ‎‪230-This server supports FXP transfers
reply: ‎‪230 OK. Current restricted directory is /
Status: Online
status: Getting Folders...
reply: ‎‪PWD
reply: ‎‪257 "/" is your current location
cmd: ‎‪TYPE I
reply: ‎‪200 TYPE is now 8-bit binary
reply: ‎‪PASV
reply: ‎‪227 Entering Passive Mode (199,119,227,145,140,143)
cmd: ‎‪MLSD
ERROR: Error Getting The Folders
*I Translated It For You From Hebrew.
Please Help.
That seems to me, it has nothing with wrong permissions.
Try to disable Passive Mode (enable Active Mode) in your favorite FTP client.
i think its the wrong permission because the error started i installed the pure ftp.
And when i hed the proftpd it worked.
And now even if i install the pro ftpd i have the same problem.
Some one know how i can change thepermissions?
