FTP Problems
xcensus
Whenever I create a ftp account within a users control panel it fails to let them login, the main domain ftp works fine, and using an ftp client allows access, but using IE it looks asthough your in, although it says Anonymous in the IE status bar, when you try to copy a file over it asks for login details again, any ideas ?
I think this is a confirmed problem with IE because of the way the username is. For example the username is [email protected]
and when you go to IE you try to input the login information with an @ sign as well which causes problem. The main ftp accounts don't have problems because they don't have the @ sign in the username.
Only solution I know of is to not use IE or use a ftp client.
