i have use csf
but the can't block all out udp port
and i have use
iptables -A OUTPUT -p udp -j REJECT
to block the udp port
but the csf some time will auto delete
i have use other way php.ini disable fsockopen
but some cms need use fsockopen
now have any good way to fix the problem
thanks
and i have use
thanks
