Heip!!help!!!
scloo
CentOS3.6
DirectAdmin will now be install on: Enterprise 3.6
Is this correct? (must match license) (y,n) : y
beginning pre-checks, please wait...
--12:54:37-- http://files.directadmin.com/services/3.6/files.sh
=> `/usr/local/directadmin/scripts/files.sh'
Resolving files.directadmin.com... 199.237.54.170
Connecting to files.directadmin.com|199.237.54.170|:80... connected.
Length: 943 [application/x-sh]
100%[====================================>] 943 --.--K/s
12:54:43 (99.92 MB/s) - `/usr/local/directadmin/scripts/files.sh' saved [943/943]
ldconfig: File /lib/libext-2.so.7 is too small, not checked.
--12:54:44-- http://files.directadmin.com/services/es_3.0/webalizer
=> `/usr/bin/webalizer'
Length: 897,080 (876K) [text/plain]
100%[====================================>] 897,080 13.12K/s ETA 00:00
13:00:19 (2.59 KB/s) - `/usr/bin/webalizer' saved [897080/897080]
adding bind-utils ...
--13:00:19-- http://files.directadmin.com/services/3.6/bind-utils-9.2.2-21.i386.rpm
=> `/usr/local/directadmin/scripts/packages/bind-utils-9.2.2-21.i386.rpm'
Length: 614,124 (600K) [audio/x-pn-realaudio-plugin]
100%[====================================>] 614,124 7.61K/s ETA 00:00
13:01:34 (8.41 KB/s) - `/usr/local/directadmin/scripts/packages/bind-utils-9.2.2-21.i386.rpm' saved [614124/614124]
warning: /usr/local/directadmin/scripts/packages/bind-utils-9.2.2-21.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e
Preparing... ########################################### [100%]
1:bind-utils ########################################### [100%]
/sbin/ldconfig: File /lib/libext-2.so.7 is too small, not checked.
adding bind ...
--13:01:34-- http://files.directadmin.com/services/3.6/bind-9.2.2-21.i386.rpm
=> `/usr/local/directadmin/scripts/packages/bind-9.2.2-21.i386.rpm'
Length: 1,779,442 (1.7M) [audio/x-pn-realaudio-plugin]
100%[====================================>] 1,779,442 8.18K/s ETA 00:00
13:04:59 (8.54 KB/s) - `/usr/local/directadmin/scripts/packages/bind-9.2.2-21.i386.rpm' saved [1779442/1779442]
warning: /usr/local/directadmin/scripts/packages/bind-9.2.2-21.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e
1:bind ########################################### [100%]
error: unpacking of archive failed on file /usr/sbin/dns-keygen;44636ebb: cpio: open failed - Permission denied
adding bind-libs ...
--13:05:00-- http://files.directadmin.com/services/3.6/0
=> `/usr/local/directadmin/scripts/packages/0'
HTTP request sent, awaiting response... 404 Not Found
13:05:05 ERROR 404: Not Found.
/usr/local/directadmin/scripts/packages/0: not an rpm package (or package manifest):
--13:05:05-- http://www.directadmin.com/named
=> `/etc/init.d/named'
Resolving www.directadmin.com... 66.51.122.131
Connecting to www.directadmin.com|66.51.122.131|:80... connected.
Length: 2,324 (2.3K) [text/plain]
100%[====================================>] 2,324 --.--K/s
13:05:06 (4.21 MB/s) - `/etc/init.d/named' saved [2324/2324]
rdate: got EOF from time server
--13:05:11-- https://www.directadmin.com/cgi-bin/daupdate?uid=3887&lid=11357
=> `/usr/local/directadmin/update.tar.gz'
Connecting to www.directadmin.com|66.51.122.131|:443... connected.
Length: 4,477,985 (4.3M) [application/x-gzip]
100%[====================================>] 4,477,985 207.94K/s ETA 00:00
13:05:30 (231.09 KB/s) - `/usr/local/directadmin/update.tar.gz' saved [4477985/4477985]
*** Cannot find the named binary. Please install Bind ***
--13:05:31-- http://66.51.122.131/named.conf
=> `/etc/named.conf'
Connecting to 66.51.122.131:80... connected.
Length: 887 [text/plain]
100%[====================================>] 887 --.--K/s
13:05:31 (93.99 MB/s) - `/etc/named.conf' saved [887/887]
--13:05:31-- http://66.51.122.131/named.ca
=> `/var/named/named.ca'
Length: 2,769 (2.7K) [text/plain]
100%[====================================>] 2,769 11.56K/s
13:05:32 (11.52 KB/s) - `/var/named/named.ca' saved [2769/2769]
Installation didn't pass, halting install.
touch: creating `/etc/virtual/blacklist_domains': No such file or directory
chown: failed to get attributes of `/etc/virtual/blacklist_domains': No such file or directory
chmod: failed to get attributes of `/etc/virtual/blacklist_domains': No such file or directory
touch: creating `/etc/virtual/whitelist_from': No such file or directory
chown: failed to get attributes of `/etc/virtual/whitelist_from': No such file or directory
chmod: failed to get attributes of `/etc/virtual/whitelist_from': No such file or directory
touch: creating `/etc/virtual/use_rbl_domains': No such file or directory
chown: failed to get attributes of `/etc/virtual/use_rbl_domains': No such file or directory
chmod: failed to get attributes of `/etc/virtual/use_rbl_domains': No such file or directory
touch: creating `/etc/virtual/bad_sender_hosts': No such file or directory
chown: failed to get attributes of `/etc/virtual/bad_sender_hosts': No such file or directory
chmod: failed to get attributes of `/etc/virtual/bad_sender_hosts': No such file or directory
touch: creating `/etc/virtual/blacklist_senders': No such file or directory
chown: failed to get attributes of `/etc/virtual/blacklist_senders': No such file or directory
chmod: failed to get attributes of `/etc/virtual/blacklist_senders': No such file or directory
touch: creating `/etc/virtual/whitelist_domains': No such file or directory
chown: failed to get attributes of `/etc/virtual/whitelist_domains': No such file or directory
chmod: failed to get attributes of `/etc/virtual/whitelist_domains': No such file or directory
touch: creating `/etc/virtual/whitelist_hosts': No such file or directory
chown: failed to get attributes of `/etc/virtual/whitelist_hosts': No such file or directory
chmod: failed to get attributes of `/etc/virtual/whitelist_hosts': No such file or directory
touch: creating `/etc/virtual/whitelist_senders': No such file or directory
chown: failed to get attributes of `/etc/virtual/whitelist_senders': No such file or directory
chmod: failed to get attributes of `/etc/virtual/whitelist_senders': No such file or directory
[root@yws root]# ls
SOS help !
sorry,my english is very poor!!!
The best way to resolve this kind of issue is to contact the DirectAdmin support group; see their webpage here.
