help,about phpmyadmin
hkeeh
Hong Kong
hello,I'm beginner for directadmin..
I'm using it for my server
Why i logon phpmyadmin...all user can see the DB?
ex..user:test logon to phpmyadmin..
but i can see other user's DB..
could help me?
thank you a lot..
(i'm install it for default)
You should be able to see all users databases, just your own.
If you're using "test" to login, then DA didn't create it because all users da creates should have username_name. If you're using the username for your DA account, then you'd be able to see all databases created by you.
If you can see the "mysql" database, then something is wrong.
hi, regarding phpMyAdmin, is there anyone who could help me set it up? i just instaled php, mysql and apache. on the phpmyadmin website it says i have to change the settings in config.inc.php, i dont know how to though and what to change it to. how do i do this?
This should be done for you when it's installed by DA. Or just run:
./phpMyAdmin.sh
to set it up again.
what is da?
and when you download it, it comes as a .zip file (im using windows)
sry i dont know to much about webservers, dos and stuff
http://www.directadmin.com
Are you a DirectAdmin customer? :) DirectAdmin (DA) is the software we sell which sets up all domains on a server. With the default install, it automatically installs all services, including apache, php, mysql, phpmyadmin etc.. and provides an easy means for setting them up.
