help me
apnacenter
/usr/local/directadmin/scripts/webmail.sh: line 58: perl: command not found
/usr/local/directadmin/scripts/webmail.sh: line 60: perl: command not found
/usr/local/directadmin/scripts/webmail.sh: line 61: perl: command not found
/usr/local/directadmin/scripts/webmail.sh: line 62: perl: command not found
/usr/local/directadmin/scripts/webmail.sh: line 64: perl: command not found
cp: `/var/www/html/squirrelmail/data' and `/var/www/html/squirrelmail-1.4.15/data' are the same file
/usr/local/directadmin/scripts/squirrelmail.sh: line 70: /usr/bin/perl: No such file or directory
## REPORT_START
Welcome to DirectAdmin verion 1.32.1!
You are now about to run the install program. If DirectAdmin is already
installed, it may destroy previous data.
Cannot find mysql in the ./scripts/setup.txt file
## INSTALL_FAILED
## REPORT_END
Permissions set
help mee plsssssssssssss
