help needed > Awstats images not showing
congkai
Singapore
Hello people, i need some help, my awstats images are not showing out and it seems like i having problem in my viewing of the awstats.
let me give a example http://mylovelyinn.com/awstats/
user: lovelyinn
pass: default
anyone know how to fix this? urgent...
Make an alias to /awstatsicons in your apache config
Alias /awstatsicons /path/to/awstatsicons
Then restart apache.
sorry, i am not so good in the settings, do you have a instruction like where to edit the apache config?
is it in conf/extra/httpd-alias.conf
or in etc/httpd/conf/httpd.conf
thanks for your help chatwizrd
Doesnt matter where you add it.
But conf/extra/httpd-alias.conf would be best for organization.
If you need to you can do this:
*Note will only work if the actual folder is named awstatsicons
echo "Alias /awstatsicons `find / -type d -name awstatsicons`" >> /etc/httpd/conf/extra/httpd-alias.conf
/sbin/service httpd restart
there is alot of path i think. i type that command, so much was found.. and are you sure of adding all in?
hi chatwizard. i found out that everytime after some time i have to go and set the commands you given to me again. today i did it again because the awstats is not showing.
is there something i forgotten to do?
