I just updated and after getting the full build when using the command:
This code (help custom build):
It seems that there is no problem with the settings in the custom build options. After the build is finished, the following message appears in the messages:
sudo apt update && sudo apt upgrade && sudo apt autoremove
da build awstats # disabled by options.conf
da build csf # disabled by options.conf
da build litespeed # disabled by options.conf
da build mod_aclr2 # disabled by options.conf
da build mod_fcgid # disabled by options.conf
da build mod_hostinglimits # disabled by options.conf
da build mod_lsapi # disabled by options.conf
da build mod_proctitle # disabled by options.conf
da build mysql # disabled by options.conf
da build nginx_apache # disabled by options.conf
da build nginx # disabled by options.conf
da build openlitespeed # disabled by options.conf
da build php 5.6 # disabled by options.conf
da build php 7.0 # disabled by options.conf
da build php 7.1 # disabled by options.conf
da build php 7.2 # disabled by options.conf
da build php 7.3 # disabled by options.conf
da build php 7.4 # disabled by options.conf
da build php 8.0 # disabled by options.conf
da build php 8.2 # disabled by options.conf
da build php 8.3 # disabled by options.conf
da build proftpd # disabled by options.conf
da build apache
da build bind
da build clamav
da build composer
da build dovecot
da build exim
da build imagemagick
da build imapsync
da build jailshell
da build lego
da build libmodsecurity
da build mariadb
da build mod_htscanner2
da build modsecurity_rules
da build netdata
da build php 8.1
da build pigeonhole
da build pureftpd
da build redis
da build rspamd
da build spamassassin
da build unit
da build webalizer
da build wp
da build php # rebuild all enabled PHP versions
da build all # rebuild all enabled software components
Install/update PHP extensions
da build php_bz2 # disabled by options.conf
da build php_gmp # disabled by options.conf
da build php_igbinary # disabled by options.conf
da build php_imap # disabled by options.conf
da build php_ldap # disabled by options.conf
da build php_phalcon # disabled by options.conf
da build php_readline # disabled by options.conf
da build php_snuffleupagus # disabled by options.conf
da build php_suhosin # disabled by options.conf
da build php_xmlrpc # disabled by options.conf
da build php_imagick
da build php_ioncube
da build php_opcache
da build php_redis
da build php_zend
da build php_extensions # rebuild all PHP extensions
Install/update web applications
da build squirrelmail # disabled by options.conf
da build phpmyadmin
da build roundcube
Components configuration options
da build dovecot_conf # Update Dovecot configuration files
da build easy_spam_fighter # Enable Easy Spam Fighter
da build exim_conf # Update Exim configuration files
da build php_ini # Update PHP configuration files
da build rewrite_confs # Rewrite WEB server configuration files
da build secure_php # Secure PHP
da build spamassassin_cron # Build SpamAssassin cron
da build sync_server_cert # Copy host name TLS certificate for services
CustomBuild related options/functions
da build create_options
da build cron
da build opt_help
da build options_nobold
da build list_removals
da build remove_items
da build set option_name value
da build update_da
da build update_versions
da build update_webapps
da build used_configs
da build versions
Remove old build data
da build clean
da build clean_old_webapps
Recommended for experienced users only (!)
da build php_htscanner2 php_release
da build set_service service ON|OFF|delete
| To build everything run: |
| da build all |
| NOTE: Command all will compile everything as it is set |
| in the options.conf file, please take a look at |
| "da build options"! |
CustomBuild installation has finished, to check the full log please check:
/var/log/directadmin/custombuild.177792629.6854598.YWxsAA.log
