HELP !!! Proftpd problems
Stephan_V
After i upgraded Proftpd 1.3.0 to 1.3.1 it keeps on returning incorrect password, after a password reset in DA it still keeps on returning incorrect password.....anyone???
code i used for upgrade
./build proftpd
Thanks for the help..
Stephan
I still get the same problems after trying your suggestion :mad:
Another suggestion anyone???
Thanks for your help Chronic
Sorry Stephan_V, i don't know any solution for your problem.
Good luck :)
Are there any errors in /var/log/messages?
cat /var/log/messages | grep -i proftpd
Check /etc/proftpd.conf
Find this line ---> AuthUserFile
Does it look like this --> AuthUserFile /etc/proftpd.passwd
