help with my DNS
thank's
Hello!
my english is very bad, excuseme.
I thank, but even I have the same problem, inside the control that buy, change him for nicared.com but now I cannot enter to the page, I thought that was problem of updating but even nothing, I bought my dns in budeghost.nl or something thus, this has his own board of control and from this I have done him, then in aid among to this forum.
Also he utilize a translator in line for this post.
Carlos, according to the whois database you've purchased the domain ghansa.com on May 1st, but there is no registration for nicared.com.
Have you also purchased nicared.com? If so, then the domain purchase didn't go through.
The nameservers registered for ghansa.com do not think they're authoritative for ghansa.com but they do think they're authoritative for nicared.com.
(You can't see that from DNS Report because since the domain nicared.com isn't in the root servers, DNS Report doesn't know to look at those nameservers.)
When you bought your webhosting, which domain did you originally buy it for?
Which domain do you want it for now?
Did you originally register ghansa.com on May 1st?
Have you ever registered the new domain name nicared.com, or did you just change the name on the DirectAdmin control panel?
I'm going to have your hosting company look at this post; perhaps they can help as well.
Hi Carlos and Jeff,
Indeed the domain name has not been registered / ordered. Carlos needs to order the domain name using te order wizard on the website.
Kind Regards,
Onno Vrijburg
aclaration
Hello!
I registered exactly the first of May, with the DNS www.ghansa.com, and quice to change it since the board of control of DirectAdmin to www.nicared.com but I do not know if should be shop new of control ó what quice I to bring up to date the DNS with a new name.
I thank them beforehand
Hallo nhack,
You cannot just change your domainname and expect the world to know that your domain name has been changed. Domain names are registered for at least 1 year and up to 10 years. You registered ghansa.com for 1 year and if you with to now use nicared.com you will need to register that domain as well. If you no longer want the domain name ghansa.com you need to cancel the domain name.
Regards,
Onno Vrijburg
thank's
llo
Thanks by its aid, but I do not understand that function has the change of control in the board of control.
which is the function of this option
Re: thank's
Making a domain change in the control panel will enable the control panel, and the hosting server, to work with the new domain name.
But you still have to buy the domain name.
Onno has already explained how you can do that automatically through his system, or in fact you can buy it anywhere, as long as you know how to point the domain name to the proper nameservers.
