principino1984
- Oct 10, 2008
I'm having a lot of problem setting up the secondary dns on my server. I added it to my server in DA and I thought it would be done. But my webfarm told me that I need to add a transfer-allow to that server. As they told me I updated my etc/named.conf file and wrote down:
but still it doesn't seem to like it, since as soon I try to send a check to the manteiner I get this error:
What can it be the problem?
thanks
Marco
	options {
        directory "/var/named";
         * If there is a firewall between you and nameservers you want
         * to talk to, you might need to uncomment the query-source
         * directive below.  Previous versions of BIND always asked
         * questions using port 53, but BIND 8.1 uses an unprivileged
         * port by default.
        // query-source address * port 53;
        allow-transfer { 213.251.188.140; };
};but still it doesn't seem to like it, since as soon I try to send a check to the manteiner I get this error:
	dns check phase ok: 10070 - xxxxxxx.ovh.net
dns check phase failed: 20801 - sdns1.ovh.net
server: sdns1.ovh.net
address: 213.251.188.140
query about tradeshell.it for record types any
trying tradeshell.it ...
query failed, 0 answers, status: server failure
tradeshell.it any record not found at sdns1.ovh.net, server failureWhat can it be the problem?
thanks
Marco
