how about mysql5.1? and 5.1 has issue with dataskq ?
tenny
i install centos 5.3 64bit and da,
i set mysql to 5.1,
i create account but the websites shows
Apache is functioning normally
i follow the article http://help.directadmin.com/item.php?id=242 to check,
all the checking point pass,
then,i run
./build rewrite_confs
and my websites work,
but i get error include
/usr/local/directadmin/dataskq: error while loading shared libraries: libmysqlclient.so.15: cannot open shared object file: No such file or directory
then,i do searching and find the thread http://www.directadmin.com/forum/showthread.php?t=30054,
andi try to downgrate the mysql from 5.1 to 5.0,
and try to run agian
and the errors gone....
i want to ask two question,
1. do you begin to use mysql 5.1 ? and do you recommend it?
2. does mysql 5.1 have any issue ?
thank you
