HOW TO FIX AFTER THE TWO DOMAIN IS NOT A DEFAULT INDEX PAGE FROM DIRECTADMIN
Iskandar
I have problem on server with directadmin. This server has been installed three times with the following cases. First the email function doesn't work. For this, an update from the forum has been carried out with the following script:
./build updates
./build exim
./build exim_conf
mv /etc/dovecot /etc/dovecot~moved
./build dovecot
./build dovecot_conf
and email can work, but then direcadmin port 2222 can't be opened
Then the server was re-installed and the email was successful even without an update, direcadmin port 2222 was normal but the process of creating a domain name for the third time experienced problems because when the domain was formed, it did not display the default display from directadmin but the apache function infi was normal. Mhn help with this. Thank you
This has nothing to do with fixing your mail and please don't double post !
People are not going to help you urgently or faster when you do that , it only irritate
How are you trying to enter the panel? with IP address or hostname ?
Check your firewall to be sure.
What about DNS settings ? using your own NS or from your provider ?
