How to fix unfinished transactions remaining. You might consider running yum-complete
nadlerz
yum update
Loaded plugins: fastestmirror
Determining fastest mirrors
* base: mirror.vit.com.tr
* extras: mirror.vit.com.tr
* updates: mirror.vit.com.tr
base | 1.1 kB 00:00
extras | 2.1 kB 00:00
updates | 1.9 kB 00:00
updates/primary_db | 529 kB 00:00
varnish-3.0 | 951 B 00:00
vz-base | 951 B 00:00
vz-updates | 951 B 00:00
Excluding Packages in global exclude list
Finished
Setting up Update Process
Resolving Dependencies
There are unfinished transactions remaining. You might consider running yum-complete-transaction first to finish them.
The program yum-complete-transaction is found in the yum-utils package.
--> Running transaction check
---> Package e2fsprogs.x86_64 0:1.39-34.el5_8.1 set to be updated
---> Package e2fsprogs-devel.x86_64 0:1.39-34.el5_8.1 set to be updated
---> Package e2fsprogs-libs.i386 0:1.39-34.el5_8.1 set to be updated
---> Package e2fsprogs-libs.x86_64 0:1.39-34.el5_8.1 set to be updated
---> Package python.x86_64 0:2.4.3-46.el5_8.2 set to be updated
---> Package python-libs.x86_64 0:2.4.3-46.el5_8.2 set to be updated
--> Finished Dependency Resolution
Log error in red.
