I am new of DirectAdmin and I would know if there is a procedure to jail/chroot Apache and PHP.
I found this 3d http://www.directadmin.com/forum/showthread.php?t=2107&highlight=jail but seems that there're some issues with http://help.directadmin.com/item.php?id=90 :
Now I would know how I could completely jail/chroot an user using Apache 2.x (http://help.directadmin.com/item.php?id=90 is only for Apache 1.3.x ) + FastCGI + PHP FCGI.
If the users are jailed/chrooted there is the possibility not to restrict the access (using safemode or open_basedir) or disable some PHP functions.
I hope in your help.
Thank you in advance.
AlbioB
- there isn't the possibility to unjail an user or delete it using DA if it is in a jail
- I have to use suPHP to jail also PHP Engine (and it slow down the system)
AlbioB
