Hi All,
After ISP changed my webserver IP on linux to set up hardware firewall, httpd service usually stops at night. I can access to web server by SSH and checked the existence of Httpd by command:
/var/log/httpd/error_log file is empty and the content of /var/log/httpd/error_log.1 is:
I can't restart httpd service and have to reboot linux server.
I also check the task schedule in linux by command:
but not find anything.
Please help me to solve the problem.
service httpd start
Starting httpd: [Wed Dec 15 06:19:42 2010] [warn] NameVirtualHost xxx.xxx.xxx.xxx:443 has no VirtualHosts
(30)Read-only file system: httpd: could not open error log file /var/log/httpd/error_log.
Unable to open logs
tail error_log.1
[Sun Dec 12 00:10:01 2010] [warn] NameVirtualHost xxx.xxx.xxx.xxx:443 has no VirtualHosts
[Sun Dec 12 00:10:02 2010] [warn] RSA server certificate CommonName (CN) `localhost' does NOT match server name!?
[Sun Dec 12 00:10:02 2010] [notice] Apache/2.2.15 (Unix) mod_ssl/2.2.15 OpenSSL/0.9.8e-fips-rhel5 DAV/2 configured -- resuming normal operations
[Sun Dec 12 00:11:01 2010] [notice] caught SIGTERM, shutting down
[Sun Dec 12 00:11:02 2010] [warn] RSA server certificate CommonName (CN) `localhost' does NOT match server name!?
[Sun Dec 12 00:11:02 2010] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sun Dec 12 00:11:03 2010] [warn] RSA server certificate CommonName (CN) `localhost' does NOT match server name!?
[Sun Dec 12 00:11:03 2010] [notice] Apache/2.2.15 (Unix) mod_ssl/2.2.15 OpenSSL/0.9.8e-fips-rhel5 DAV/2 configured -- resuming normal operations
[Sun Dec 12 04:02:04 2010] [notice] SIGHUP received. Attempting to restart
[Sun Dec 12 04:02:04 2010] [warn] NameVirtualHost xxx.xxx.xxx.xxx:443 has no VirtualHosts
crontab -l
