httpd problems..
djmitch
I've almost 2 months no problems whit my server... but yesterday there was a site that used suddenly much mysql connections.. i blocked it him and al the other sites on the server where faster again... but when i now deblock him, so that he can change his site the following things happen:
First httpd stops..
I start it again.
5 secs later it stops..
I start it again.. and now blocked that person again so the httpd stays online.
If you now block a other site and do the same.. httpd again stops for 2 times and then it just runs normal (i think)
Here is a bit of my logs apache error_log in the map: httpd:
Sun Dec 17 04:03:02 2006] [notice] mod_security/1.9.4 configured - Apache/1.3.37 (Unix)
[Sun Dec 17 04:03:03 2006] [warn] pid file /var/run/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Sun Dec 17 04:03:03 2006] [notice] Power MOD by web4host.net mod_ssl/2.8.28 OpenSSL/0.9.7a PHP/4.4.4 mod_perl/1.29 FrontPage/5.0.2.2510 configured -- resuming normal operations
[Sun Dec 17 04:03:03 2006] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sun Dec 17 04:03:03 2006] [notice] Accept mutex: sysvsem (Default: sysvsem)
[Sun Dec 17 04:58:44 2006] [error] [client 74.6.74.161] File does not exist: /var/www/html/robots.txt
[Sun Dec 17 05:03:34 2006] [error] [client 85.158.248.47] Invalid method in request echo
Segmentation Fault in 6693, waiting for debugger
[Sun Dec 17 06:05:37 2006] [error] [client 74.6.74.161] File does not exist: /var/www/html/robots.txt
[Sun Dec 17 06:51:32 2006] [error] [client 74.6.74.161] File does not exist: /var/www/html/robots.txt
[Sun Dec 17 06:51:35 2006] [error] [client 85.158.248.47] Invalid method in request echo
[Sun Dec 17 07:56:06 2006] [error] [client 74.6.74.161] File does not exist: /var/www/html/robots.txt
[Sun Dec 17 08:37:34 2006] [error] [client 85.158.248.47] Invalid method in request echo
[Sun Dec 17 08:52:16 2006] [error] [client 74.6.74.161] File does not exist: /var/www/html/robots.txt
[Sun Dec 17 09:13:47 2006] [error] [client 201.45.247.6] mod_security: Access denied with code 500. Pattern match "^GET (http|https|ftp)\\\\:/" at THE_REQUEST [severity "EMERGENCY"] [hostname "www.integra.tv"] [uri "http://www.integra.tv/prodCrmProd.asp?idm=EN"]
[Sun Dec 17 09:13:47 2006] [error] [client 201.45.247.6] File does not exist: /var/www/html/500.shtml
[Sun Dec 17 09:53:06 2006] [error] [client 66.249.72.98] File does not exist: /var/www/html/robots.txt
[Sun Dec 17 10:09:25 2006] [error] [client 74.6.74.161] File does not exist: /var/www/html/robots.txt
[Sun Dec 17 10:23:35 2006] [error] [client 85.158.248.47] Invalid method in request echo
[Sun Dec 17 11:36:37 2006] [error] [client 74.6.74.161] File does not exist: /var/www/html/robots.txt
[Sun Dec 17 11:48:02 2006] [notice] SIGHUP received.  Attempting to restart
[Sun Dec 17 11:48:33 2006] [notice] mod_security/1.9.4 configured - Apache/1.3.37 (Unix)
[Sun Dec 17 11:48:34 2006] [warn] pid file /var/run/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Sun Dec 17 11:48:34 2006] [notice] Power MOD by web4host.net mod_ssl/2.8.28 OpenSSL/0.9.7a PHP/4.4.4 mod_perl/1.29 FrontPage/5.0.2.2510 configured -- resuming normal operations
[Sun Dec 17 11:48:34 2006] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sun Dec 17 11:48:34 2006] [notice] Accept mutex: sysvsem (Default: sysvsem)
[Sun Dec 17 11:49:01 2006] [notice] SIGHUP received.  Attempting to restart
[Sun Dec 17 11:49:23 2006] [notice] mod_security/1.9.4 configured - Apache/1.3.37 (Unix)
[Sun Dec 17 11:49:24 2006] [warn] pid file /var/run/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Sun Dec 17 11:49:24 2006] [notice] Power MOD by web4host.net mod_ssl/2.8.28 OpenSSL/0.9.7a PHP/4.4.4 mod_perl/1.29 FrontPage/5.0.2.2510 configured -- resuming normal operations
[Sun Dec 17 11:49:24 2006] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sun Dec 17 11:49:24 2006] [notice] Accept mutex: sysvsem (Default: sysvsem)
Segmentation Fault in 2969, waiting for debugger
[Sun Dec 17 11:58:02 2006] [notice] SIGHUP received.  Attempting to restart
[Sun Dec 17 11:58:53 2006] [notice] mod_security/1.9.4 configured - Apache/1.3.37 (Unix)
[Sun Dec 17 11:58:54 2006] [warn] pid file /var/run/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Sun Dec 17 11:58:54 2006] [notice] Power MOD by web4host.net mod_ssl/2.8.28 OpenSSL/0.9.7a PHP/4.4.4 mod_perl/1.29 FrontPage/5.0.2.2510 configured -- resuming normal operations
[Sun Dec 17 11:58:54 2006] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sun Dec 17 11:58:54 2006] [notice] Accept mutex: sysvsem (Default: sysvsem)
[Sun Dec 17 11:59:02 2006] [notice] SIGHUP received.  Attempting to restart
[Sun Dec 17 11:59:11 2006] [notice] mod_security/1.9.4 configured - Apache/1.3.37 (Unix)
[Sun Dec 17 11:59:12 2006] [warn] pid file /var/run/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Sun Dec 17 11:59:12 2006] [notice] Power MOD by web4host.net mod_ssl/2.8.28 OpenSSL/0.9.7a PHP/4.4.4 mod_perl/1.29 FrontPage/5.0.2.2510 configured -- resuming normal operations
[Sun Dec 17 11:59:12 2006] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sun Dec 17 11:59:12 2006] [notice] Accept mutex: sysvsem (Default: sysvsem)
I can see that there happen some strange thing but i can't see why..
Maby my cron?
Dec 17 11:55:01 linehosting crond[3243]: (boxing) CMD (/usr/local/bin/php /home/boxing/public_html/cron.php?cron=5min)
Dec 17 11:56:01 linehosting crond[5502]: (root) CMD (/usr/local/directadmin/dataskq)
Dec 17 11:57:01 linehosting crond[5546]: (root) CMD (/usr/local/directadmin/dataskq)
Dec 17 11:57:26 linehosting /usr/bin/crontab[5548]: (root) DELETE (mitch)
Dec 17 11:58:01 linehosting crond[5603]: (root) CMD (/usr/local/directadmin/dataskq)
Dec 17 11:58:11 linehosting /usr/bin/crontab[5637]: (root) REPLACE (mitch)
Dec 17 11:59:01 linehosting crond[5750]: (root) CMD (/usr/local/directadmin/dataskq)
Dec 17 12:00:01 linehosting crond[5938]: (root) CMD (/usr/local/sysbk/sysbk -q)
Dec 17 12:00:01 linehosting crond[5940]: (boxing) CMD (/usr/local/bin/php /home/boxing/public_html/cron.php?cron=5min)
You can see that i've unblocked and blocked that account... and in that time httpd does strange things...
I don't know what to do.... i didn't change anything on the server...
Here some extra info:
Uptime: 66 days, 18:52
Load: 0.08, 0.14, 0.12
Memory: 810M / 946M
Swap: 68M / 956M
What do i have to do ?
EDIT:
I have now tried to deblock (again) the site that gave yesterday many load.... first nothing happens... (12:19) but when i visit one site on the server (not the person that i just deblocked) httpd stoped (12:20) i started it.... and now when i visit it just stayed online.. when i visit the site that i have deblocked it stays online... it just looks normaal, but why httpd stopted?
Here some logs again:
[Sun Dec 17 12:11:36 2006] [error] [client 85.158.248.47] Invalid method in request echo
[Sun Dec 17 12:15:06 2006] [error] [client 82.157.120.71] File does not exist: /var/www/html/403.shtml
[Sun Dec 17 12:15:07 2006] [error] [client 82.157.120.71] File does not exist: /var/www/html/403.shtml
[Sun Dec 17 12:15:12 2006] [error] [client 82.157.120.71] File does not exist: /var/www/html/403.shtml
[Sun Dec 17 12:15:13 2006] [error] [client 82.157.120.71] File does not exist: /var/www/html/403.shtml
[Sun Dec 17 12:15:16 2006] [error] [client 82.157.120.71] File does not exist: /var/www/html/403.shtml
[Sun Dec 17 12:15:19 2006] [error] [client 82.157.120.71] File does not exist: /var/www/html/403.shtml
[Sun Dec 17 12:15:24 2006] [error] [client 82.157.120.71] File does not exist: /var/www/html/403.shtml
[Sun Dec 17 12:15:25 2006] [error] [client 82.157.120.71] File does not exist: /var/www/html/images/no.gif
[Sun Dec 17 12:15:25 2006] [error] [client 82.157.120.71] File does not exist: /var/www/html/403.shtml
[Sun Dec 17 12:15:30 2006] [error] [client 82.157.120.71] File does not exist: /var/www/html/403.shtml
[Sun Dec 17 12:15:31 2006] [error] [client 82.157.120.71] File does not exist: /var/www/html/403.shtml
[Sun Dec 17 12:15:35 2006] [error] [client 82.157.120.71] File does not exist: /var/www/html/403.shtml
[Sun Dec 17 12:15:36 2006] [error] [client 82.157.120.71] File does not exist: /var/www/html/403.shtml
[Sun Dec 17 12:15:41 2006] [error] [client 82.157.120.71] File does not exist: /var/www/html/403.shtml
[Sun Dec 17 12:15:49 2006] [error] [client 82.157.120.71] File does not exist: /var/www/html/403.shtml
[Sun Dec 17 12:15:55 2006] [error] [client 82.157.120.71] File does not exist: /var/www/html/403.shtml
[Sun Dec 17 12:15:56 2006] [error] [client 82.157.120.71] File does not exist: /var/www/html/403.shtml
[Sun Dec 17 12:15:58 2006] [error] [client 82.157.120.71] File does not exist: /var/www/html/403.shtml
[Sun Dec 17 12:16:02 2006] [notice] SIGHUP received.  Attempting to restart
[Sun Dec 17 12:16:06 2006] [notice] mod_security/1.9.4 configured - Apache/1.3.37 (Unix)
[Sun Dec 17 12:16:07 2006] [warn] pid file /var/run/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Sun Dec 17 12:16:07 2006] [notice] Power MOD by web4host.net mod_ssl/2.8.28 OpenSSL/0.9.7a PHP/4.4.4 mod_perl/1.29 FrontPage/5.0.2.2510 configured -- resuming normal operations
[Sun Dec 17 12:16:07 2006] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Sun Dec 17 12:16:07 2006] [notice] Accept mutex: sysvsem (Default: sysvsem)
the time on my pc or server isn't good, but in the time from the server (12:16) the httpd stopt
Cron logs:
Dec 17 12:15:01 linehosting crond[8491]: (root) CMD (/usr/local/directadmin/dataskq)
Dec 17 12:15:09 linehosting /usr/bin/crontab[8506]: (root) REPLACE (crazysezer)
Dec 17 12:16:01 linehosting crond[9334]: (root) CMD (/usr/local/directadmin/dataskq)
Dec 17 12:17:01 linehosting crond[9999]: (root) CMD (/usr/local/directadmin/dataskq)
Generally when no one replies it's because no one knows the answer.
You're getting a segmentation fault.
There's probably an improper setting somewhere causing the segmentation fault if it only happens with one particular domain unsuspended but not when it's suspended.
Another common source of a segmentation fault is faulty memory.
