i need help with mysql
adamp
hellow
i need to allow remote access to my mysql
how can i do it?
thank you
make sure that port 3306 is open on firewall
then in DA under MySQL there is section to manage the remote ip address.
i think that you not understand the problem
i want to contact to MYSQL from other computer
yes, I did understand what u were asking and my reply is correct as well
mysql runs on port 3306, so in order to allow the external traffic to connect to mysql u need to make sure that the port 3306 is open for connection
also u also need to create an entry using DA to allow external access to mysql DD by creating a un and pw
but i need to do something on the mysqld config
to allow remote access.
You can add a new user via phpmyadmin (logging in as root)
and use a % in the host box
so every host kan remotly login to your mysql server
how i can do this?
you can write what to do
You can use DirectAdmin too to change users external host.
Login in DirectAdmin
Goto "MySQL Management"
Select the user that must have external login permitions.
And type in the host box a % character,
press add to finish.
Now you can login remotly with that user.
Dries
Dries
to do this from DA
