SeLLeRoNe
Super Moderator
I need a help, i need to install the following package:
libdbi-dbd-mysql
For merlind but, ive got this problem on installing:
The libmysqlclient.so.15 exist and ive tryed several time to install from guide in help.directadmin.com
Anyone can help me to fix this issue for install that package?
libdbi-dbd-mysql
yum install libdbi-dbd-mysql
--> Running transaction check
---> Package libdbi-dbd-mysql.x86_64 0:0.8.1a-1.2.2 set to be updated
--> Processing Dependency: libmysqlclient.so.15(libmysqlclient_15)(64bit) for package: libdbi-dbd-mysql
--> Processing Dependency: libmysqlclient.so.15()(64bit) for package: libdbi-dbd-mysql
--> Finished Dependency Resolution
libdbi-dbd-mysql-0.8.1a-1.2.2.x86_64 from base has depsolving problems
--> Missing Dependency: libmysqlclient.so.15(libmysqlclient_15)(64bit) is needed by package libdbi-dbd-mysql-0.8.1a-1.2.2.x86_64 (base)
--> Missing Dependency: libmysqlclient.so.15()(64bit) is needed by package libdbi-dbd-mysql-0.8.1a-1.2.2.x86_64 (base)
Error: Missing Dependency: libmysqlclient.so.15()(64bit) is needed by package libdbi-dbd-mysql-0.8.1a-1.2.2.x86_64 (base)
Error: Missing Dependency: libmysqlclient.so.15(libmysqlclient_15)(64bit) is needed by package libdbi-dbd-mysql-0.8.1a-1.2.2.x86_64 (base)
You could try using --skip-broken to work around the problem
You could try running: package-cleanup --problems
package-cleanup --dupes
rpm -Va --nofiles --nodigest
