ImageMagick problem
norhost
I have been checking around, but i cant find a solution.
When installing ImageMagick I get this error when doing a version check.
[root@domain bin]# convert -version
convert: error while loading shared libraries: libMagickCore.so.1: cannot open shared object file: No such file or directory
Any one know whats wrong here?
Ron
Set your LD_LIBRARY_PATH to include the /usr/local/lib directory
# export LD_LIBRARY_PATH=/usr/local/lib
Bye
Type ldconfig
I had this same error. The solution for me was to type this at the command prompt after compiling and installing:
ldconfig
I'm still something of a beginner, but as I understand it this "registers" any new libraries you've installed.
Why this isn't included in the installation instructions is beyond me.
tried that and still get errors in gallery. Although running /usr/local/bin/convert returns imagmagick corectly
ldconfig
Thank you! This fixed my problem... Still not working with PHP but now looking to see if I have to recompile PHP for use with ImageMagick.
Regards,
Phil
